Question about LG WM2016C
A bathroom rug unbalanced my LG frtldr and even made some small dents. It was insane sounding and I got to it in less than a minute...but the damage was already done. Also, the rubber lining, while still attached, was twisted. Now my husband decided to dig in and fixed the unattached spring(s), and also the rubber lining. So I tested it by doing a load of one set of dbl flat/fitted sheets and four std pillow cases. about 40 minutes later there is water all over the garage floor (about 2ft wide w/out exaggerating) and the "IE" error flashing. also, when I opened the door some water came out so it must not be draining...properly. Ugh...is this going to be a possible semi-easy fix...or is this poc done? It is less than two yrs old...which makes me ill. The model is LG WM2016CW Any ideas you can muster would be greatly greatly appreciated. And, my husband 99% of the time is awesome w/repairing things. So i'm just trying to collect info for him!
We had this same problem rug and all.......... Did you ever get it fixed?
Posted on Nov 06, 2010
On a Maytag Maxima XL front load washer, please tell me on what cycle to wash a bathroom rug. zo vs
the heaviest cycle there is . but it sounds like the control board is not advancing the timer if it sits that long on one thing perhaps a call to a repairman is called for .
Jun 22, 2015 | Maytag Neptune MAH5500B Front Load Washer
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
THE WASHING MACHINE WASHES THE CLOTHES BUT WHEN IT COMES TO "SPIN"THE MACHINE STOPS. SPIN ICON KEEPS ON BLINKING.
Check your drain pump. It is on the front lower side of the machine. There is a small door which opens to it. Unscrew the filter and the pump cover. Be careful when you do this. There is a small drain hose next to it. Use this hose to drain to a pan before opening the filter lid.
Aug 16, 2014 | LG Washing Machines
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Damaged Insignia NS-L32Q-10A Screen
The damage actually occurred on the LCD (liquid crystal display) itself, not on the screen. Therefore, when the tv is switched off, no damage is visible. What happens is that when it is turned on, the liquid crystals "leak" because the display is broken. This is why you can see lines and a small dent. Depending on the tv, replacement LCD panels may be sold separately, though chances are that it would cost less to simply buy a new tv. Thanks for your post, and I wish you the best of luck! Sincerely, Der Strom
Apr 26, 2010 | Insignia IS-LCDTV32 32 in. Television
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
Small dents in stainless steel refrigerator
Find one of those auto body dent dent repair guys. They are the people that can pull the hail damage dents out of cars. Its worth a try.
Jun 14, 2009 | LG LRFD21855 Stainless Steel French Door...
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
LG WM2016C Logo
121 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
