CANON C6000 IMAGEPRESS MACHINE NOT WORKING BECAUSE ERROR E000075-0001-05
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 82 Answers
SOURCE: Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Posted on Dec 10, 2009
  • 64 Answers
SOURCE: canon imagepress c7000vp error code
The laser shutter is faulty. The laser unit is faulty. The potential measure
Posted on Jan 18, 2010
  • 71 Answers
SOURCE: error e020 0180 on canon imagepress c1 please give
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Posted on Jan 24, 2011
  • 3 Answers
SOURCE: Hello, can you tell me
this is fixcinx releted error
Posted on Aug 22, 2011
I have a machine canon imagepress C6011VP with error E00000-0201-05
hi if u get error E00000 as main code that's mean the heater problem
u should have to check the hater lamp and the thermal fuse in fixing unit if every things are good this is only malfunction just reset error code.
Oct 27, 2014 | Office Equipment & Supplies
When I turn on my canon ImagePress C1+ printer it stays in warmimng up state and never gets ready. what is wrong? how can I fix it?
when i turn my conon imagepress c1 printer it state and this error code come it e00001 - 001 what the problem and how can i fix it
Nov 17, 2013 | Canon Imagepress C1 Color Copier,...
Canon ImagePress C1 cannot calibrate from Windows 7
The problem is it doesn't recognize Java 7. Install Java 6 (latest version) and it will work. You can have both Java 6 and 7 installed at the same time. As well make sure if you are running a 64bit machine you install the 32bit version of Java (so you will have 4 versions installed). Java 7 32 & 64 bit, Java 6 32 & 64 bit. I had the same issue and solved it this way.
Jul 26, 2012 | Canon Imagepress C1 Color Copier,...
Waste toner canon imagepress c1
if it is the 2nd transfer cleaning waste toner, you have to clear copier-counter-misc-2TC-Box
Jun 10, 2012 | Canon Office Equipment & Supplies
Error e020 0180 on canon imagepress c1 please give me a reply
Solution :
Dec 19, 2010 | Canon CLC 1120 Color Copier
Canon imagepress c7000vp error code e000061-0481-05. what does it mean??
Jan 16, 2010 | Office Equipment & Supplies
Dec 10, 2009 | Office Equipment & Supplies
I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Explanation
there is no site other than looking at the specs for each machine at canonusa.com. As for the 3170 the 70 series is just a newer version of the 3100 however I would not recomend purchasing a used 3100 they are labor intensive. And yes the CLC series is old and outdated. The imagepress is its own beast, that machine runs very well.
If you are looking at buying a used machine in the 30 page per minute range I would go with a IRc3200, 3220 same as before the 20 is just the newer one.
Jul 29, 2009 | Canon Office Equipment & Supplies
463 people viewed this question
k24674
jasbo
jasbo
