Question about Thermador SC302T Electric Double Oven
I to clean my lower oven .I have a notice show E 14 in the digital window ?
  • marcelo quiroga Aug 23, 2010
    Daniel,
    My oven is lock I not able to open the notice like I said before E 14
  • 4,323 Answers
Hi
Error E14 means latch switch problem. It may have happened due to a loose latch switch or due to loose wiring on the latch switch. To troubleshoot the issue, turn the clock selector knob to OFF. Adjust the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
However, if the issue is not resolved then you'll need to replace the latch switch. Turn the power off at the circuit breaker and open the door, you will need to remove the vent cover that goes around the door latch assembly, remove the latch assembly and check the latch wiring as well. Check this link for the schematics of your oven---
Thermador SC302T Electric Double Oven Schematics
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
  • Daniel Scott
    Daniel Scott Aug 23, 2010
    Hi
    As I said in my previous post you'll need to replace the door latch. To do this open the upper door, and Pull out on the door. Take a metal coat hanger and put a 2" bend at 90 degree angle, put the coat hanger 2" to the right of center at the bottom of the door until it hits the oven can. Now turn rotate the coat hanger until the bent part is down and move it to the left. This will unlock the door. Now remove the 2 screws on the grill and pull it forward. Watch the wires on the door switch. Now you can get into your oven and remove the latch. You will need to remove the vent cover that goes around the door latch assembly, remove the latch assembly and check the latch wiring as well. Check this link for the schematics of your oven---
    Daniel
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
GE stove model GRSR3620SM-2 Self Cleaning Cycle Not Working.
my first thought would be a loose connection at the element or main power terminal. it could be a relay board issue also
Jan 08, 2012 | GE Profile JTP18 Electric Single Oven
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
Bottom oven trips cicuit breaker.
As a licensed electrician I've dealt with similar situations many times before.
Your connections are getting bad (loose, carboned up and corroded) from the continual over loading and over heating. This causes more resistance and thus more voltage drop causing higher amperage. It's time to either replace the entire sub-assembly or the oven, it's just going to continue to get worse and will eventually cause damage to the bus in your breaker box.
Jun 21, 2010 | Neff U1721 Double circotherm Electric Oven
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Cleaning Inside the Glass Window
u will have 2 take the door apart to remove glass
Mar 27, 2010 | Maytag MEW6630D Electric Double Oven
The oven is 100 degrees colder then the read out
press bake and set to 550degrees. within 2 seconds press and hold the bake until 2 digits show on display, then release bake. the digits displayed is the amount of degrees the oven is off from original factory setting. If it reads 0, it is at original factory setting. you can now adjust by pressing the up button for a hotter oven, down for lower. it can only be done for 35 degrees. when done, hit clear/off. this will help to close the gap. if you are using an inexpensive thermometer, it can take a very long time for it to read the actual temp in the oven.
Nov 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Aug 31, 2009 | Frigidaire 30 in. Electric Double...
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
65 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
