Question about Princeton Digital LCD1510 15" Flat Panel LCD Monitor
How many cords attach to back of monitor? - Princeton Digital LCD1510 15" Flat Panel LCD Monitor
    Sergeant:
  • 237 Answers
Two cords
one for power supply
another for data with multi pins in it
Posted on Aug 21, 2010
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
TFT8000 18.1 in. Flat Panel LCD Monitor: Was given the monitor with only a video cord. Pow...
It may have failed Backlight inverter circuits. You just need power AC cord and the VGA cable to attach to the PC VIDEO card. Try it on another PC.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Compaq TFT8000 18.1" Flat Panel LCD...
ViewSonic VA720 monitor will not turn on just a blinking light.
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 17, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Do not know what plug ins to attach to computer I have power to the screen and it is on screen saver. I do not know what screen cords and attachments to use? None of the usual printer cords fit the back of...
It's very likely what you call the flat plug is the video cable. (Picture #1) below. The corresponding cable looks like (Picture #2). The other cable (A/C) by elimination plugs into an electrical outlet. Are you seeing a cable other then this one coming out of the back of monitor? d82bfa4.jpg697a779.jpg
Nov 29, 2009 | Mitsubishi Diamond Pro 91TXM 21" CRT...
Where is the power source? Monitor came with no cord and cannot locate the power source input.
On the back of the monitor you should find three prongs that plug onto the female end of the power cord. The monitor power cord will look the same as your computer cord.
Oct 01, 2009 | View and View Technologies Computers &...
After unhooking Dell monitor, can't get it to work again.
hELLO THERE:
You shouldnt have to hook both of them up.
turn off the computer and monitor unplug. the power cord to the power supply. leave the monitor hooked to the computer
remove the side panel on the left side of the computer.
look and find the wiring harness from the powersupply to the motherboard and remove it now press the power button on the computer for 1 minute this releasess any (esd) or Electronic Static Discharge. that may have built up over time.
wait for 3 minutes
during this time this will be a good time to blow out any dirt or debris that may be in the inside of the computere
now reinstall the wire harness back to the motherboard and connect everything back up and turn on the computer and then the monitor and see what happnes you should be ok after this ok?
let me know how this goes ok and please dont forget to rate the solutions that i have provided for you
best regards michael
(USN RETIRED)
Aug 06, 2009 | Dell UltraSharp 1905FP LCD Monitor
Wiring installation for back up camera monitor
yes the black is ground, the red goes to a constant power in the fuse block , and the blue goes to the reverse wire to activate the monitor
Feb 25, 2009 | Virtual Reality Black Vr3 Wrless Backup...
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Monitor won't turn on
Doesn't it turn on even when you boot your computer? Try unplugging the power cord and the cable attached to your video card, plug it in while it is not attached to your computer to see if it encounters the same problem. If so, the monitor might be busted, if not then just reattach and try again...
Dec 09, 2007 | Sony SDM-HS75/B 17" LCD Monitor
Princeton Digital LCD1510 15" Flat Panel LCD Monitor Logo
37 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Sunday Ojelabi
Sunday Ojelabi
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
