Question about Panasonic AG-W1 VHS VCR
I my TV is NTSC, I have video converter, I wanted to digitize a PAL video I dont't have a manual for My Panasonic AG w1,
  • Panasonic Master
  • 5,342 Answers
You might be able to get the manual free from the Panasonic website.
Posted on Aug 23, 2010
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Dec 14, 2016 | Panasonic Televison & Video
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
I go dvx 100a ntsc and i just want to know its posible to changed to pal ????
You can not change a camera from NTSC to PAL. The systems are completely different and there is no way anyone can do it even the manufacturers would not bother with that.
What you can do however is to take your picture using NTSC then you get to an editing suite like Adobe Premiere Pro CS4. If you upload or capture your NTSC video in the PAL environment of Premiere Pro then you will have that converted automatically but there will be changes to be made by adjusting picture size and so on. This I found out can be done with very little picture quality loss. Though with some cameras sound syncing can be something you might have to work on.
Oct 07, 2011 | Panasonic AG-DVX100 Mini DV Digital...
Can I manual convert my TC-26LX85 from NTSC to PAL from time to time?
Hello fabulouspr,
You would need NTSC to PAL video digital converter box. Check your electronic stores that sells TV's, if not search for these online to purchase. Good luck.
-Joe
Aug 28, 2011 | Panasonic TC-26LX85 26 in. LCD HDTV
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
Conversion of PAL (B) into NTSC
you will need a pal/ntsc digital video converter
Dec 01, 2007 | Sony KP-53S65 53" Rear Projection...
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
Urgent - pal ntsc
Pal and NTSC are different formats. If you live in Canada, you?re TV most likely supports NTSC and not PAL. If you bought your TV and it said it is multisystem, so you won?t have problems with if, but i am almost sure this is not you case. If you want it for your PC, you will need to get a program to change your videos from PAL to NTSC. What I would recommend you to do is to buy a miltisystem camera; the format transformation isn't the easiest way. Daniel
Sep 06, 2005 | Panasonic AG-185 Camcorder
Televison & Video Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
