Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing code F02, what is that?
    President:
  • 1,382 Answers
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Posted on Aug 21, 2010
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not wash complete load. flashed f02, water not draining
F02 stands for long drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
you can press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
you might want to check..
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem most probably you will have to replace the pump
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
4. Check the drain pump filter for foreign objects.
Sep 27, 2009 | Kenmore Washing Machines
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover ultima code F-02 flashing
Jul 17, 2009 | Washing Machines
Control panel flashing F02
the water in your drain pump is still forzen...its taking to long to drain...ckeck drain hoses too...onthejob
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
