Question about Microwave Ovens
Westinghouse oven model EW050SB#01 electric oven. The oven door does not close properly allowing hot air to escape. The door usually only opens about half way making it difficult to get anything out of the bottom tray. I assume that the door has not been installed correctly? Your help and assistance is appreciated Thank you Bruce New Zealand
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool GT4185SK Keypad does not work - oven starts as soon as door is closed
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
Another thing that can cause this is steam or grease / smoke getting in the controls. The best way to prevent this is to be sure your hood exhaust fan is on whenever you cook on the stove top.
If it does not dry out over time, it may need to be manually dried or blown out.
I've followed up to your by e-mail address to be sure I help you fully.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: How much clearance do you
That really doesn't sound like enough, but to be sure, you should consult your owner's manual.
If you don't have the manual, you may be able to download one free here: http://service.us.panasonic.com/OperMan
Posted on Jul 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Posted on Mar 06, 2009
Microwave still buzzing and not getting hot.I changed out the diode, HV transformer, and the magnotron. can some one help me. I already paid the ask-a-tech $30 to get this far.
The one thing you have not mentioned is the high voltage capacitor that is part of the high voltage section, this part does fail and in some cases causes a load on the supply line making the microwave buzz or blow the line fuse killing the power to the oven.
Jun 29, 2011 | Maytag MMV4205 Microwave Oven
Panasonic nn-t775sf microwave oven not getting hot, i measured the two diodes on the inverter power supply one is open and one is shorted anyone have a service manual? or idea part number to replace them
Before you do all of that, please check the door safety interlock switches for proper operation. These switches report to the oven if the door is open or closed. Forget what you know about the door, the oven needs to be told and in the simplest of terms. If you regularly open the door with the oven operating, you have probably damaged the contacts of the tiny switches. If the contacts do not close (open) properly, they don't report the door as being closed and as such, the oven will not turn on the heat (magnetron).
If you find these switches are operating properly, I suggest you check with www.repairclinic.com for your parts or with a FixYa.com advertiser whose message you will find around this page.
Thank you for your interest in FixYa.com
Mar 13, 2011 | Microwave Ovens
Will not operate. Does have power as the clock works.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
Since this is posted under R-530BS, I'll assume that's your model number.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
If that's not your model, feel free to contact me directly with your model number.
If you only need a switch, you can order a universal type here for $5 postpaid.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 29, 2010 | Sharp R-530BS Microwave Oven
Sharp Carousel Model R-1440 starts running when door is shut firmly
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
It will be either the very top or very bottom one, not the middle one.
You can find part ordering help here. I recommend that you bookmark that link to your favorites.
Nov 27, 2009 | Sharp R-1480 Microwave Oven
Kenmore Elite Advantium 120, model # 363.63693301, display working, exhaust fan and exterior lights work, won't heat in microwave or convection mode. What could it be?
You probably just have a bad primary interlock (upper door switch) or its mount is loose or broken.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
For more on door switches & mounts, see:
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
But if you need any cosmetic parts,
enter your full model number at the Sears parts site.
Jul 08, 2009 | GE Advantium 120 Convection/Microwave Oven
The jcm9158aa jenn air microwave cooks fine, but the fan and light do not turn off when the microwaving is complete. In order for the fan and light to turn off, you have to open the door or turn off the...
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Also see:
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Jun 25, 2009 | Maytag JMC9158AA Microwave Oven
WON'T HEAT OR CLOSE DOOR PROPERLY. ALL ELSE SEEMS OK
Well firstly if the door wont close properly you shouldnt use this device as if you are in the kitchen whilst it is in use your slowly cooking yourself . If the door is open microwaves can escape and that is Radiation Lethal if you get too much or too close ?.
The reason it is not heating is probably because most of the microwaves are escaping and not bouncing around your oven cooking your food .. but actually bouncing around your home cooking you . My advise to you is get it repaired by a qualified Domestic appliance engineer or bin it and get a new one ..
Regards Vortash
May 12, 2009 | Microwave Ovens
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Clock
Nov 21, 2007 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
181 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
