Question about Vizio L32 32 in. LCD HDTV
Powers on but no picture and no sound how do you fix yourself and what parts do you need
  • 11,361 Answers
It can be the power supply has gone out or it is in protection shutdown mode due to short circuits in the power supply or in the backlight inverter board, you will need to check the power supply DC output voltages with and without the backlight inverter board connected to the power supply.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 21, 2010
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
My veon 32" has no picture but sound only
Hi my veon tv is 50inch LED turning on green then off red but no picture it had sound but not any more so no picture or sound can't find reset either and is 2 years old please help.thank you
Nov 24, 2013 | Televison & Video
No picture
Hit F2 to brighten the screen. No picture could be any one of these things you need to buy.
1. New inverter board
2. New LCD backlight
3. New power board/sound board
4. New Logic board
If the parts and repair labor becomes cost prohibitive, then look into a new laptop, unless your handy and can replace the parts yourself.
Mar 23, 2010 | Apple MacBook Mac Notebook
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
Red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
Jun 21, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Kvg21q1 no picture no sound and led not standby power on........
That's correct. As you have no picture and no sound, you need to replace flyback and power transistor.
What i would advise you that you can purchase the flyback and Horizontal output resistor online and you can also fix it yourself. That would help you save certain bucks.
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 22, 2009 | Sony KV-35V35 TV
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
No Picture or Sound and chirping from rear
Most likely there are defective capacitors in the power supply. The chirping you are hearing is the attemt to fire up the supply. The cold may have been enough to cause the caps that were on the verge of failing to completely fail. This should be a simple repair for any shop. If you wish to attempt the repair yourself, let me know and I'll try to get you mode details on the likely defective parts.
Dan
Feb 13, 2009 | Philips 51PW9363 51" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
Hitachi Ultravision 57T
the problem you are describing sounds like a vertical output ic problem could be it needs to be resoldered or could be defective and needs to be replaced if you are handy you can do the repair yourself a repair shop would be at least about 100.00 for service call and problably 150.00 or more for repair but if you are handy I can post you a link where you can get the IC with free online tech support to do this repair yourself
Apr 23, 2008 | Hitachi 57F500 57" Rear Projection...
Vizio L32 32 in. LCD HDTV Logo
177 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
