Question about Microwave Ovens
My pitco SGH50 fryers keeps backfiring. - Microwave Ovens
It is a rival 4.5l. the heating element does not work anymore. need to replace it.
If I read the title it say PROBLEM WITH THE MICROWAVE, on the other hand when I Google the Rival 4.5L it is a deep fryer?!?!?, now if you'r talking about a Microwave oven there is NO heating element, what produces the heat is called a MAGNETRON... it can be replaced but it's cheaper to buy a new oven. Now if you'r talking about a deep fryer, you are correct there is an element inside the unit but as for it's replacement you need to check if it is servicable, some models are riveted meaning you can not disasemble it without braking the rivets... if you finally get it appart check the element for a part number if it has one than it's just a matter of calling a near by applayance store and order it (it would be even better to show the element to the clirk) than again the element could cost as mutch as a new fryer...
Cheers!
Sep 03, 2011 | Microwave Ovens
I'm looking for a manual and drawings for the Lang deep Fat Fryer, type CLF-15-1 230 Volts, 60 hz
I am so glad I am able to help you -
Gary @ Fix Ya
Jul 11, 2011 | Microwave Ovens
My fryer has broke ; i accidentally switched it on when there was no oil.. what do i do ??
The heating element has gone, cheaper to replace the fryer with a new one.
Jun 08, 2011 | Microwave Ovens
Looking for a replacement cord for Philips deep fryer model 6161
Hi, you can get the replacement cord to your Philips deep fryer on this LINK..............
Apr 20, 2011 | Microwave Ovens
We have a SM35GMS fryer (Propane) Will light but after a few seconds it will shut off.
Most Gas things have a Thermistor that heats and keeps open the gas valve if this is faulty thyen the gas valve will not remain open but close after you let it go....this could be your fault
Feb 22, 2011 | Microwave Ovens
Where can I buy the Philips airfryer in the USA?
The quick recommendation chart below lets you compare features of the bestselling air fryers and where to buy Best Hot Oil less Air fryer Review 2015
Jan 16, 2011 | Microwave Ovens
Breville bdf deep fryer keeps tripping out /turning off have to push reset buttons to get it started again after having to wait 10 mins to reset
That sounds like either a faulty thermal trip, or a faulty overheating fryer.
Is it clean around the element because if not the heat will build up, much like the fur on a kettle and cause the element to overheat.
Hope this helps.
Jan 02, 2011 | Microwave Ovens
Ok we have a fry master natural gas fryer serial number 0401LP0001 model number BIH252CSD and we are trying to figure out if it has to be hooked up to a 220 plug or if we can use a 110?
look on the back of the fryer for an info sticker/plate that lists the specs for the unit...you'll see the voltage and phasing required for it...as an example, the picture below shows a 208V 3 phase unit...in general, i think 110V full size fryers would be rare if they exist at all...
Oct 16, 2010 | Microwave Ovens
I have as yet to get the right answer and help for what I have ask for. I received 2 answers for detachable cords 1. for a motercycle 2. for electric meters etc. I need a detachable cordset for an Ultrex...
Hi:
Don't know the specs on your cord, but you can try Aubuchon Hardware at 1-800-431-2712 they have a universal repl cord 6' long with 1and 1/16" pin spacing for $6.99 part # 652573,hope it helps, couldn't trace your cords model #...dan
Oct 05, 2009 | Microwave Ovens
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
