Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Can you tell me where I can find on and off pins for my a/c timer. only have 2 need more my timer is Model #HB114 240 V 60HZ
Open following link to identify Intermatic trippers and product number.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Intermatic store sells the trippers
http://www.intermaticstore.com/
Also web search for the tripper number, since many places sell them besides Intermatic store.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
Diehl Timer 4 pin wiring
well..the timer is used in a variety of dryers. which model is this one going to be installed in?
Oct 15, 2008 | Dryers
WHERE CAN I FIND DIRECTIONS TO PROGRAM TIMER #0148373
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 19, 2010 | Hardware & Accessories
My timer is not like this one, it is a PIN TIMER JAC T35 & has pins
Open following link to identify timer, and then add a comment and say what model you have and what problem is:
http://waterheatertimer.org/GE-timers-and-manuals.html
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I have A Time All Model TB 211 and need to learn how to set the time with the pins. Have no manual. Using for my Xmas lites, on and off. Outdoor use.
There are two 2 basic types for mechanical timers: Pins and segments
geno_3245_149.jpgTimer pins flip in and out using fingernail.
geno_3245_150.jpg Timer segments lift up using small tool or fingernail
geno_3245_151.jpg Sometimes segments pull outward away from center
To check timer functions after setting pins or segments, manually rotate dial to and watch lights turn on and off.
Dec 07, 2010 | RTO Intermatic #HB51RC Photo On/Off Out...
Whwere are the pins to set the tomer on the 59204 model? Thanks
Woods 59204 is a plug-in timer rated for 1250Watts incandescent
The pins are 48 'segments' located around outer edge of dial;
Segments pushed toward center of dial = timer OFF for that 1/2 hour
Segments pushed out = timer ON for that 1/2 hour
Nov 18, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Instructions:
Turn ON lamp.
Light bulb is good.
Dec 30, 2009 | Kitchen Appliances - Others
I have the GE Plug in Mechanical Timer Model 15119. I have the pins pulled up on the white side at 5 and on the black side at 5 and the side setting on the timer position. Yet when I plug it in the wall...
We had the same problem when we first tried to set our timer. Although we have a newer model, this might work for your timer as well. The pin for each 1/2 hour interval that you want the device to be "on" must be pushed toward the perimeter of the dial, not the center of the dial. For each 1/2 hour interval that you want the device off, the pins should be pushed toward the center of the timer. Don't forget to move the arrow on the dial to the current time just before plugging in the timer. Be sure the switch on the side of the timer is moved to "timer on", the override is "outlet on" for when you want your device to come on during the time that the timer is set to have your device turned off.
Dec 27, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
