Question about Honeywell Programmable Thermostat Heater
A/C won't kick on w/ Honeywell RTH230B The thermostat went out and needed the batteries changed. I changed the batteries but now the AC unit will not respond or switch on even after waiting the 5 or so minutes for compressor safety. I have tried to reset it several times over a period of a couple hours but still no luck. The unit has worked fine and the AC was running earlier today without any issues.
  • 2 more comments
  • galwaychase Aug 21, 2010
    none of those suggestions worked thanks though for your help
    this was attempted last night but even in 'Manual' mode the thermostat is not triggering the AC to turn on, the fan in the furnace will work when that function is turned to 'On' but will not run the fan when in 'Auto'
  • galwaychase Aug 22, 2010
    thanks apparently it was easier than that the 'new' batteries I used apparently weren't all that new and once again shutting everything down and removing the batteries for 1/2 hour then reinstalling fresh batteries that were actually fresh set everything right again thanks for you help
    sort of
  • Honeywell Master
  • 43,501 Answers
Okay it seems that for some reason the battery change scrambled the brain of the t-stat... that happens...
To fix it you will now have to go into the "Installer Menu" and reset the paramenters of the t-stat.
If you have the Installe brochure then you can look in there and then set the tistat for "heat/cool" and also to "auto fan" and then to "auto changeover" These should get you back to cooling again...
No big problem, just a small programming issue...be patient and if you do not have you book don't worry... you can look it up here...this tip tells you where and how to find any of the Honeywell t-stat manuals.
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Posted on Aug 21, 2010
    New Friend:
My solution is: Never buy this **** again. I follow this rule myself. I'm sick and tired of hearing why programmable is so far superior to the old mercury switch. Well, never had to re-program that one. Off-On / Heat-Cool and preferred temp. Leaving? Turn it off. Returning? Turn it on. Brilliant! No manuals, high-priced repair people or computer science degree needed. Gadgetry is not always better.
Posted on May 20, 2014
You will need to reprogram the thermostat. Click on the link below to view the Honeywell RTH230B user manual
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1800.pdf
Honeywell Customer Care: 1-800-468-1502
  • 17,130 Answers
Please check if the temp setting on the panel is lower than the existing temperature in your room. If so push up the settting to give more cooling. Put the AC off for some 30 minutes , reset and put it on again., remove the battery , keep aside, if leaked clean well.
If there is no result you will need to check if the main unit is detecting the signals, manually try to see if the compressor relay works. Checking on the unit can determine if there is a controller failure, relay failure although this cant be the case as the unit worked.
So we shall point to the fault in the thermostat section, preset the program once again, if the thermostat is OK , the connections are OK, then it must work but give time.
Hope my tip works.
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Cool air not working with honeywell Model # RTH230B
Do you have a heat pump? If so, not compatible. What i did was move the jumper on the thermostat (RH RE). This is on the inside of the thermostat - NOT the red jumper!!! and got the AC working (the heat had already worked during the winter, problem only became apparent when I needed to use AC). I may have to change the jumper again when the season changes...not sure yet.
Apr 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Can't Program Clock for Honeywell RTH230B Thermostat
After you set the hr, min, and day, press the mode button.
Oct 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
8,102 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
