Question about Fujitsu Siemens LifeBook N3010 Notebook
Where is the cpu battery? - Fujitsu Siemens LifeBook N3010 Notebook
  • 342 Answers
Your laptops battery can be seen under the laptop.you can eject it by pressing a switch near it.
Posted on Aug 21, 2010
Changed cpu on packard bell imedia d3318, still getting no signal on monitor and no beeps. When I remove the cpu and power on, there are no beeps
Have you check with different RAM, Did you try to reset BIOS by removing the CMOS battery and shorting CMOS jumper? Your Processor may be ok but you are plying with it. When there use to be no display then first thing you should doubt with the CMOS battery and the RAM and Motherboard, rather then CPU, CPU hardly gives problem.
Aug 14, 2012 | HEWLETT-PACKARD Computers & Internet
Is high CPU usage will make battery life reduction?
Anything that requires more activity from your CPU will shorten the battery charge. It is eating power. I am not sure about "Magician".
Jan 13, 2012 | HP Computers & Internet
Laptop won't boot turns on then off after about
Your Laptop seems to be full of dust - Maybe your CPU Heat sink FAN cannot turn because if this THUS causing your laptop to heat up and shut down again to prevent your CPU from receiving damage due to high temperature.
Close your laptop lid, then put the unit on its backlcd. Make sure you disconnect the Battery and the A/C Power chord. With the emty battery slot is facing you, take note of the screw that is facing you to the right on the bottom cover. There might be others like this in the same area. The cover that you need to remove is of rectangular shape, and the largest cover.
When you have removed it you should see the CPU Heat sink and a FAN. This is the part where you blow the unit out at that spot with compressed air so that the dirt will no longer block the heat from venting away from the laptop mainboard/cpu.Please check if the CPU FAN is still turning licenly. If it doesn't turn or very difficult - replace .
[ADVANCED]
Then, remove the 3 screws from the CPU heat sink and thereby remove the HEAT sink completely. Remove the CPU Heat sink FAN and clean it as nessesary. Use a small flat to switch the CPU from closed to open and remove it. Then clean it with a cloth and ethanol - make sure you remove all dirt and old heat sink paste on top if it. make sure you do not touch the bottom of the CPU and handle the pins carefully.
When you are done, place the CPU back and reaaply a eyedrop of fresh heatsink paste onto the CPU, lock the CPU switch again. Then clean the backside of the CPU heat sink where it rests on the CPU. When you are done with that, place the CPU heat sink back onto the CPU then screw the 3 screws back onto the CPU heat sink and onto the mainboard. Keep the sequence in mind. Reconnect the CPU Heat sink FAN to power on the mainboard with the cable then place the cover back onto it. Tighten all screws again and reconnect battery and A/C Power chord.
Jun 04, 2010 | Acer TravelMate 4230 Notebook
CPU Speed showed in My PC Lower than real one.
Check your CPU out on CPU WORLD, some of those older intel processors has a speed switch on them. You just enabled it it the bios but its not apparent until you start taxing the CPU.
May 08, 2010 | IBM ThinkPad T30 2366 Notebook
Warning cpu been changed re enter cpu setting en the cmos fet
Cmos drop usually means it's time to replace the motherboard BATTERY. A new battery and one more reset should fix this problem, if not, check for loose mobo connections. As a last resort, consider having the board and CPU tested for electronics issues.
Jan 28, 2010 | Biostar P4M900-M4 Motherboard
Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Oct 06, 2009 | ASUS P5GD1-VM Motherboard
On boot up the bios is stating the CPU was changed. But it was not.
Usually that is the first signal that the battery is drained and needs to be changed. Yes you are right, go ahead and change the onboard battery and set the time & date after that.........sodeep
Apr 15, 2009 | Computers & Internet
BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Dec 12, 2008 | Abit KV7-V Motherboard
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
CPU
test the bios battery, it should read 3vdc. if that fails, remove the bios battery, remove and re-socket the cpu and memory, then hook the bios battery back up. once booted, go into the bios, restore factory or fail-safe defaults, save, and reboot.
let me know if this helps,
trin
broken french translation:
examinez la batterie de bios, elle devrait lire 3vdc.
si cela échoue, enlèvent la batterie de bios, l'enlèvent et re-douille l'unité CPU et la mémoire, puis accrochent le dos de batterie de bios vers le haut une fois initialisé, entrent dans le bios, reconstituent l'usine ou les défauts fiables, économiser, et les rechargent.
faites-moi savoir si ceci aide,
trin
Nov 13, 2007 | Computers & Internet
Fujitsu Siemens LifeBook N3010 Notebook Logo
294 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
