Question about Lexicon MC-12 Balanced Amplifier
Where can I find reliable, cost effective repair to my lexicon mc12 HD?
  • 4,234 Answers
A place called "The Service Bench" located in Massachusetts is an authorized service center for Lexicon. Contact them.
Dan
Posted on Aug 23, 2010
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Mar 30, 2008 | Lexicon MC-12 Balanced Amplifier
I'm having this issue with MC12 HD, the signal would go off for a second or flickers twice every now and then even on the blue control screen of the MC12 HD. Any advises please.
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - Setting all auto settings to off, like auto protection, mpeg noise filter, digital ... Two of my friends have full hd samsung lcd tv's but i have never ... My TV blinks (screen only goes black for a split second or two) .... Ive got an 8000 series & itdoes the same has yours mate,it is also flickering while the picture is on ...Missing: mc12 ‎twice
Jan 01, 2016 | Televison & Video
I have cracked the screen it made a flash then nothing now a light blinks can it be repaired only 2 months old
The screen itself cannot be repaired - only replaced. Since it is the most expensive component in the entire unit, it is probably not cost effective to pay the cost of repairing it. Between the price of the part itself and the labor to replace it, you can probably find another unit somewhere on sale for less.
Nov 13, 2015 | Panasonic Viera Tx-P42s30b 42-Inch Full Hd...
My lexicon mc 12 pre amp won't power on. The lead
There may be a secondary fuse inside the unit, if not the problem will be in the power transformer, if you are handy with a digital post back and I will give instructions on testing the transformer.
Jun 09, 2012 | Audio Players & Recorders
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Jul 06, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Hi ihve soundcraft efx12 & the problem is in the effect, it hanges if i use the program selector, all the leds related to lexicon effects lit up.ithink the problem is in the the lexicon card. please...
If the LED's are level indicators, you are probably saturating the input of the effect and may cause it to hang. Effects use delay and feedback and can cause numerical overflow and the system to basically crash. I would first call the Lexicon support and ask them about this problem... I did have to return one Lexicon product myself for service under warranty.
Mar 25, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
On powering up, the lexicons LCD display Audition light flashes for about 6-7 secs, then "21" appears then"UP". After this none of the buttons/Diald work-it just freezes. I have been...
hola tengo el mismo problema, me han dicho que actualizando el firmware de la lexicon mx200 se soluciona pero resulta que mi pc no reconoce el dispositivo via USB para actualizarlo, alguna solucion?? muchas gracias
Mar 18, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
How do I connect effects rack (Lexicon) to Tascam 2488 MK 2?
I've got a Lexicon too and I love the thing.
To use the Lexicon as a 'send effect' (which is what it is) you'll need to connect the effect sends from the back of the 2488 to the inputs on your Lexicon. Then connect the outputs from the Lexicon into two inputs on the 2488. Then assign those inputs to tracks.
You've got to select the previously recorded track(s) where you want to add reverb or other effects (by pressing the select key) and then press the 'send' key to get into the 'send effect' screen. Here you can adjust the amount of signal is sent from that channel to either of the effect sends (typically you might want to send one track of a stereo set of tracks out eff 1 and send the other track out eff 2).
Pre, post or off will determine whether the fader affects the signal being sent or not and the loop setting on the top of this screen is for the internal effects.
Once you've got this set up the way you want you just arm the tracks where the Lexicon output is coming into the 2488 for recording, mute whatever you don't want to hear and you can bounce record the raw signal through the Lexicon and record (print) the effected signal on the tracks you've armed.
Hope this helps.
bd.
Lexicon MC-12 Balanced Amplifier Logo
185 people viewed this question
Top Lexicon Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Electric Dime
Electric Dime
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
