Question about Saniflo & Saniplus& Macerator Pump
Toilet will not work. when plugged it it hums even if i dont push the button,
    Scholar:
  • Saniflo Expert
  • 115 Answers
When the unit is humming it could be something stuck on the blade or impeller preventing it from spinning. The drain pipe can be clogged or the capacitor which drives the blade and impeller may have gone bad. Tipically when the capacitor goes bad it will just hum and not pump the waste out.
Posted on Aug 25, 2010
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 | Home
Bath or shower does not empty,the saniplus hums then stops.but after 30 mins or so suddenly starts working.
Is your Saniplus humming or motor spinning slow or not at all?
It is likely the internal motor control capacitor - It is the most common replacement part for these units and a fairly simple DIY although you will need rubber gloves and bleach.
I have posted repair instructions for the Saniplus here:
Saniplus Repair Instructions
Jun 17, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
Recently, one of my toilets won't flush properly. It is my guess that during a recent visit, a friend threw an apparently disposable object in the toilet. Since then, it won't completely flush unless I use...
May need to remove the toilet and see if the object is in the loop of the toilet drain inside the toilet-if so you can manually reach inside sometimes to remove object-if it has passed and is in your line below your floor now that the toilet is off you can use the auger or a garden hose with a thin sprayer set to high force that down into drain if you cannot see the object and see if you can push it thru to your septic tank or sub station tank depending what you have-if that dont work --hello roto rooter-
Oct 02, 2017 | Home
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
May 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Hi i have a saniplus macerator unit hums but
sounds like an obstructed unit - you would need to remove the impeller cover at the base to check the pump - i'm assuming youve already checked the blade unit at the top (be careful here - i use a screwdriver - not my finger) could be that a simple cleanup and acid descale would be all thats needed. try this first then start looking deeper.Humming indicates motor is ok - but dont let it run continuosly - you dont want to burn out a good motor.
Dec 05, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Insinkerator has power but does not grind garbage. have hit reset button and turned allen screw at bottom. now i dont get a hum from the motor.
Is it hardwired or does it plug into an outlet? If it plugs in, check the outlet for power. Is a circuit breaker tripped? How do you know it has power if it doesn't even hum?
Oct 14, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Aug 01, 2009 | Villeroy & Boch Home
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
PEAVEY TRANSTUBE AUDITION 110. PLUG UNIT IN POWERS UP . SITS THERE AND HUMS LOUDLY. SPEAKER WORKS. plug guitar in can hear it faintly, push lead chanel button in , hum gets super loud. HUM IS IN PROPORTION...
There should be an 8 pin IC close to the input jack that will be marked 4558 or 4560. This is an Op-amp Ic that is the most likely cause of the problem. Replace that IC and report the results here.
Dan
May 27, 2008 | Audio Players & Recorders
Saniflo & Saniplus& Macerator Pump  Logo
270 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
