Question about Garden
My 6 mo. old Dremel 4000 suddenly won't power up. Just nothing. It was fine yesterday. It is used quite a bit doing home restoration work, but nothing over-bearing. The carbon brushes look fine to me....other thoughts?
  • 3 Answers
SOURCE: Dremel model 395, Type 5
Brushes are usually conducting carbon sticks at one end of the rotator (spiny bit in middle of motor) there will be two (opposite each other) connecting to the commutator (round copper looking ring with slits in it). The brushes will each have a spring that pushes them onto the commutator and a wire to carry the electricity to the brush.
As the rotator spins, the brushes connect to different coils via the commutator. This allows the electricity to energize the next set of coils to make the motor spin more.
If the motor gets very hot the brushes can stick in their housing and loose contact.
My Dremels (and type) all have the motor cooling exhausts and intakes where you need to hold them. It is quite hard to not block them during use..
I would also get hold of a multi-meter or continuity checker and check that the lead into the motor has not broken inside. Another common problem.
Posted on Aug 01, 2008
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw won't work
OK sounds like you are handy. You have electric to the brush tubes? (first unplug saw to test) If yes then I would remove the brushes to see if they were making contact with the commutator. Does the blade spin freely? If not you might have a bearing problem. I would again use air after removing the brushes and then reinsert making sure they seat on the armature. If still nothing then if you are comfortable I would pull the motor housing. But before pulling go to Bosch Tools website and downloading a breakdown of your saw. Let me know if I can help
Posted on Jan 15, 2009
rowdy45176
  • 2176 Answers
SOURCE: My Ryobi 10 inch miter saw, model TS 1340 has been
It sounds like the armature has developed an open commutator bar. What did the brushes look like that you took out. But before I assume the worst I would unplug the tool and remove both brushes and with a flas light look into the brush tube while slowly rotating the armature looking for a discoloration or raised bar. If not you might bet by with cleaning the commutator with a special stone for this, you might be able to get one at the repair shop where you bought the brushes. If you want to send me the photo of the arcing it might help on my end. Let me know
Posted on Mar 09, 2009
SOURCE: Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Posted on Jan 07, 2010
mt375hp
SOURCE: which dremel bit do i use for sharpening some scissors and how?
there is a sissor angle attachment and an orange stone
Posted on Jan 20, 2010
The collet nut won't completely tighten down to keep a drill bit or what ever I'm using in place .
make sure nothing is broke down inside of it or some type of shavings try sprayin wd40 down it
Feb 08, 2016 | Bosch Dremel 4000 Rotary Tool Kit...
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the...
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
Jun 04, 2011 | Samsung N150 (36725723009) Netbook
I bought a dremel 4000 on ebay and it didn't have a manual with it - I need basic instructions to use the drill bits I purchased that go with it. Is there an adaptor that I need to use them?
Your drill bits side, should have a twisting hand tightening head into which you insert the bits, and have fun. If this is missing, you can either buy it, at dremel stores, or get a nut of the same thread and get the job done.
Sep 07, 2010 | Dremel Drills
I have an old dremel tool model 270. I just
If you are saying that the grout tool that you bought is a bit you hoped to use in one speed dremel, I would not use it if the manufacturer of the bit specifically said not to. If you are saying that you purchased a tool that operates separately and doesn't need to be power by the dremel, that is different. I can tell you that manufacturers never tell people not to use their product unless there is a pretty good reason! So, if it is the first scenario I advise you not to use the bit in the dremel.
Nov 15, 2009 | Hand Tools
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
