Question about Meade ETX-70 (240 x 70mm) Telescope
First time using the mead etx 60at. I turned it on and set the date / time / enter. Then set it at north and horizontal,enter. It asked if i wanted the easy alignment, I said yes. I said searching. Then it said the name of astar and said it was slewing but the telescope isn't moving.
  • 3,186 Answers
Did you lock down BOTH clutches?
You should have Calibrated motors and trained drives before you actually tried to do a goto.
Read this manual completely:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-60-70AT%20manual.pdf
Posted on Aug 21, 2010
Hi I have a meade 125ext. On using the "auto
First thing to try is a NEW hand controller cable. If this does not fix it, then you have an electrical short or bad circuit board inside. Only Meade can repair this.
Try the cable before you panic.
Nov 17, 2010 | Meade ETX-125 (250 x 125mm) Telescope
Adjustment lever part is for the ETX 60AT tripod leg. Two of three are okay but the third is broken. Never been out of the box.
Contact Meade directly for any replacement parts. You might also find something at a well stocked hardware store that will also work.
http://www.meade.com/support/index.html
Aug 30, 2010 | Meade ETX-60 AT Telescope
Bought the scope about 4 years ago. Fairly light use and not used in last 12 months. Was checking it recently and replaced batteries etc. Horizontal motor movement is fine however no vertical motor...
Do a RESET on the hand controller. Re-enter Time, Date, and SITE, and CALIBRATE motors.
Also sometimes a bad hand controller cable will cause this. You can buy another cable directly from Meade. Call them here:
Aug 16, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
My Meade ETX-125EC Telescope has a broken horizontal lock lever where can I get a replacement? thanks
Meade can probably sell you one :
You might also find something that would work to tighten it at a well stocked hardware store.
Apr 18, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
60at motor fault
Could be several things:
You did Train the drives and CALIBRATED motors using the same power source you will use outside?
Do not run off of the internal batteries UNLESS they are brand new. Once the batteries drop below about 70% the hand controller goes a little crazy. That's why most people use an external power pack.
1. Replace the batteries, and do a Calibrate motors.
Did this fix it?
Mar 21, 2010 | Meade ETX-60 AT Telescope
MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
Jul 23, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Horizontal moter problem
This is probably not what you want to here but it most like needs to go back to Meade for repair. There website is here: http://www.meade.com/.
You may want to also check here for further support: http://www.weasner.com/etx/menu.html. Mike Weasner is quite knowledgeable about the ETX line.
Good Luck!
-jodair
Jan 30, 2009 | Meade ETX-90EC (325 x 90mm) Telescope
Changing the coordinates of the autostar for meade etx 125
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Dec 12, 2008 | Meade ETX-125PE (500 x 127mm) Telescope
Meade etx-80 sticking
Some (not all) versions have an end stop - it it just reaching that? The scope will rotate only aboit 3 complete turns between the 2 ends.
The 'correct' starting position is as follows: Place scope on tripod or table with control panel at the West. Unlock the declination lock (horizontal slew). Rotate scope anticlockwise until it hits the end stop, Then roate it back clockwise until scope is pointing North (should be about 3/8 of a turn, as the end stop is at South West). Then lock the declination, Set the tube horizontal and continue with the alignment process.
Autostar always thinks you have set the position like that. If you haven't, it will work OK until it tries to rotate past the point it won't go, then chaos results!
Feb 12, 2008 | Meade ETX-90 (48x90 mm)
Meade ETX-70 (240 x 70mm) Telescope Logo
171 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
