Question about AudioBahn A2801Q Car Audio Amplifier
Is the audiobahn a2801q 1 ohm stable in bridge mode?
  • 3 Answers
No it is not. You will melt that amp trying that. It is only good for 4 ohms mono and two ohms stereo.
Posted on Aug 21, 2010
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
Does an audiobahn A2801Q throw 1000 watts
Hello... I can help you with this question. This particular amplifiers specifications are as follows:
  • 200 watts x 2 @ 4 ohms stereo
  • 280 watts x 2 @ 2 ohms stereo
  • 560 watts x 1 @ 4 ohms mono
    These specifications are RMS power, which would mean continuous "real" power output. Hope this helps!
    20 year car audio/video installer
    Bay manager
  • Mar 15, 2011 | AudioBahn A2801Q Car Audio Amplifier
    How many watts does a audiobahn a1502dp have
  • RMS Power Rating:
    • 150 watts x 2 chan. @ 4 ohms
    • 300 watts x 2 chan. @ 2 ohms
    • 450 watts x 2 chan. @ 1 ohm
    • Bridged, 300 watts x 1 chan. @ 4 ohms
    • Bridged, 600 watts x 1 chan. @ 2 ohms
  • http://www.sonicelectronix.com/item_2304_Audiobahn-A1502DP.html
    Feb 23, 2011 | AudioBahn A1502DP Car Audio Amplifier
    How should i arrange the wiring on my xm-zr1852 xplod amplifier to get the best performance out of my 12'' audiobahn subwoofers?
    it depends on the impedance of the subs-if your subs are dual 4 ohm coils then you can parallel the coils which will give you 2 ohms per sub- you could get max performance from your amp by just wiring the 2 ohm speaker load to each channel of the amp which will hit them with about 200 watts rms each. another way to do it is to wire the coils in series which will make each sub an 8 ohm load and then parallel them together and that will show a 4 ohm load -which you can use to run the amp safely in bridged mode. This will give you exactly the same amount of power to your subs as in 2 ohm stereo will. so with your amp being 2 ohm stable in stereo or 4 ohm stable in bridged mode- those are the numbers you want to hit for maximum"safe" operation
    Dec 10, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    I have a audiobahn a400t and im running 2-12''jh45 mtx jackhammers the speakers are wired in parallel stabel @ 2or1 ohm. the speakers are in a ported box. how do i run my wires to my hook these up right to...
    Hello rattle822,
    A pair of JH4512-04's can be wired to 2 ohms if the subs themselves are paralleled. There's only one voice coil and it's 4 ohm. If wired in series, the final impedance to the amp would be 8 ohms. They cannot be wired to 1 ohm.
    In bridged mode, your 4-channel amp is only stable down to 4 ohms. You can bridge 2 of the channels to provide a relatively low 200 watts RMS X 2. The best power solution for your subs would be to bridge channels 1 and 2 and wire one sub to it. Likewise, bridge channels 3 and 4 and connect the other sub. If you connect both subs in parallel, the impedance will be too low causing the amp to overheat and possible fail.
    As for the settings: Low pass filter on, crossover somewhere between 80-100, input levels to match your receiver, and bass boost to your personal preference.
    Hope this helps.
    Aug 13, 2009 | AudioBahn Car Audio & Video
    Wiring a 10 inch dual voicecoil dub100 so its bridged the right way
    yes sir. You can find out every single option for the amount of subs and the impedence. This will show you your wiring options. Plus remember when you bridge your amp you are Halving the ohm that is going to the 2 channels. SO if it is stable at 2 ohm at each channel. And you already have a 2 ohm load from your subs your amp will go into protection over and over again and eventually fry up cuz you will be putting 1 ohm load at each channel.
    May 06, 2009 | AudioBahn DUB100 Car Subwoofer
    I HAVE A A2300HCT AUDIOBAHN I WANT TO CONECTED TO 6 12 INCH CROSSFIRE ALL 6 GIVE ME 1 OHM DO YOU THINK I CUOLD LOWER THE AMP TO 1 OHM IF NOT WHATS MY BEST CHOICE
    Hello VICENTEMULGA,
    According to Audiobahn's specifications, the amp is stable at 1ohm, either with the channels driven separately or in bridged mode. With the channels driven separately, the rated output is 1,200 watts at 1 ohm. In bridged mode, the rated output is 2,400 watts.
    You'll need an absolute minimum of 2gauge power and ground, and preferably 1/0gauge and a really good alternator to provide enough current for the beast.
    Hope this helps.
    May 05, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    How bridge the 15" 800 rms speakers audiobahn
    parallel wiring (if your amplifier is 1 ohm mono stable)
    All positives together and all negatives together.
    If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
    Here is a wiring link.....
    http://www.the12volt.com/caraudio/woofer_configurations.asp
    Dec 16, 2008 | AudioBahn AWES15P 15" Subwoofer Car...
    Amp a2801q
    Audiobahn A2801Q
    Product Description:
    Class A/B MOSFET Circuitry
    Volt Meter With Blue Illumination
    PWM MOSFET Power Supply
    Double Sided Glass Epoxy Circuit Board
    THD: 0.02%
    S/N Ratio: >100dB
    Frequency Response: 10Hz - 40KHz (+/- 1dB)
    Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
    Variable 18dB Low-pass Crossover: 30Hz To 120Hz
    Bass boost @ 45Hz: 0/18dB
    Subsonic Filter: 20Hz to 50Hz
    RCA Throughput Connections
    3-way Protection Circuitry: Thermal, Short Circuit and Overload
    Cooling Fan
    Cobalt Blue Illumination
    High gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
    1-year warranty
    Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
    DUB2502 amp
    you probably have the speakers set to where it ecxeeds the ohm load limits. its only 4 ohm stable when bridged and two ohm stable when ran using two channels. so either run the speakers at 8 ohms each parallel or just hook one speaker to eack channel. if you do not know what i am talking about then just email me at grandam88@hotmail.com and give me the speaker specifications.
    Oct 07, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
    AudioBahn A2801Q Car Audio Amplifier Logo
    64 people viewed this question
    Top AudioBahn Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Colin Stickland
    Colin Stickland
    Jerry Naidoo
    Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
