Question about KitchenAid KSRG22FKSS Side by Side Refrigerator
Door needs to be adjusted, dropping down - KitchenAid KSRG22FKSS Side by Side Refrigerator
  • 4,070 Answers
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Aug 21, 2010
Closing door on the Miele CVA 4060, it needs to be lifted slightly to engage the male boss / pin to guide it into the rebate in the body. Is this a normal way to close the door?
The door has dropped down.You can fix this by having a strong person or a jack lift the door back up a little.
Just open the door a few inched and lift it about 2 inches at the rear of the door.Adjust it up more if needed or push down on it if needed,to get a nice closing door.
Feb 25, 2018 | Cars & Trucks
Whirlpool fridge door "drops" into place when opening.
are both door leveled? if not the door cam worn out and need replacement
Nov 23, 2017 | Whirlpool GSS30C6EYW 30 cu. ft....
DOOR LEAKING
Check to see if door is warped or dropped down. Adjust same. Clean boot & door where they meet with detergent. Door lock mechanism worn & not holding door closed tightly. Some model have adjustments on door.
Dec 21, 2013 | LG WM-2277HW Front Load Washer
My Craftsman 1/2 horsepower garage door opener will not close when properly whenever the temp drops below 40. Why is this?
Define "close properly".
When it gets cold nothing moves easily. The door requires more force to move. The opener will apply a set measure of force before giving up and switch directions (both up or down). This maximal force applied (up and down separately) is adjustable. The purpose is to prevent a person from being squished to death by the door. As the door moves up, apply resistance to it. If it doesn't take much to cause it to go the other way (or stop), then you need to adjust. If it will lift you as well, then you need to adjust. Do the same as the door goes down.
Feb 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Eurogas oven door
If it is a drop down door, then generally speaking it is the door hinges nthat need replacing, as they are mot usually adjustable.
Hope this helps.
Jan 06, 2010 | Ovens
Main oven door not sealing. How do you adjust the cam type action of the hinges to ensure flush seating of the door? thanks
If it has a drop down door, then no adjustment is possible, the only solution is to replace both hinges.
Please rate my solution.
Thanks.
Nov 11, 2009 | Electrolux Ovens
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
My whirlpool double oven lower door won't stay closed all the way. model RBD305PD810. is there an adjustment that is needed?
If it is a drop down door, then you need to replace both door hinges, if it is a door that opens sideways, then it is probably the door catch, or door striker that needs to be replaced.
Thanks.
Nov 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Door drops down 1/8' when open. To close need to
If the model number you have this listed under is correct, there is no adjustment. More than likely the door pivot and/or hinges are worn. They can easily be replaced, however. The part numbers are as follows:
Door Pivot - 8184922
Upper Door Hinge - W10114255
Lower Door Hinge - W10114254
You can find these parts at appliancepartspros.com. Just type in the model number and locate items 6, 8, and 13 under the "Door Parts" heading.
If you have questions about this repair, or have a different model number, please post back and let me know so that I may be able to provide better assistance. I hope this helps you.
Aug 25, 2009 | Whirlpool GH5184XPQ Microwave Oven
KitchenAid KSRG22FKSS Side by Side Refrigerator Logo
105 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
