Question about Whirlpool Refrigerators
Leakage of water from freezer - Whirlpool Refrigerators
    Sniper:
  • 66 Answers
This is known for many refrig.
here is a solution to LG refrigerator that you might learn from
Have fun
Avi
Posted on Jan 13, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Ok, I'll give quick solution for you. Tell your problems, I can confirm the problem actually comes from the freezer, due to excessive clotting in the freezer, precisely at the cavity insulation or air ducts from the freezer to lower the freezing container is covered by ice. so that the cooling in the lower container is not maximal.
How to repair:
If you understand and know where the refrigerator TIMER. you can set the timer to the defrost function. sign is the compressor will stop when the timer is set to defrost, the ice melting process by a part called HEATER , will occur in the Freezer.
If you do not understand, the easiest way is, Unplug your refrigerator electric outlet and allow you to not use the fridge for a while until you confirm yourself all the ice frozen in the freezer had melted. can be seen from a water reservoir that is located under your refrigerator. usually a tray that can be withdrawn. the main problem is the Ice melting covered by Ice frozen in hole of a water reservoir so the the wate leakage to front door. .
Ok then, hopefully this solution can help you.
Posted on Aug 21, 2010
  • 4,059 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
How do i fix my lg multi flow fridge/freezer that trips the earth leakage all the time
It may be possible the defrost heater is shorting to earth or ground. This would trip the GFI every time the refrigerator went into defrost. It also is possible that water has infiltrated the insulation and causing a leakage current. This would be much harder to fix.
Mar 22, 2015 | LG Refrigerators
Water is collecting and freezing on the bottom freezer.. Overflow water is leaking on to floor,
bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Mar 12, 2015 | Whirlpool Refrigerators
I have water collecting and freezing on the bottom freezer. The overflow is leaking on the floor.
Bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Water leakage
Probably the drain line from the freezer is clogged with debris or it is frozen. Empty the freezer and shut it off and defrost the line and check the drain line for proper flow.
Mar 27, 2014 | Daewoo FRSU20IA Freezer
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
One veg crisper fills with water, no matter what the humidity control is set at
model? top mount or sxs ?? if top freezer ck for leakage from drain under freezer . it may need cleaning so the condsate water drain properly . very common problem mm
Dec 07, 2009 | Dryers
Water leakage from the door
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water in front of freezer - hissing noise from back of freezer every so often
Check if there is any water leakage, most likely the sound is from the expansion device.
May 04, 2009 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
