Question about Apple iMac G5 Desktop
I am getting 3 vertical lines appearing on my screen.It started with one and now has increased to three.Two white and one yellow.
  • leighton_lin Sep 04, 2010
    Thank you. I did just that and they are covering completely under an extended apple warranty. No hesitation and directed me to the nearest qualified Apple techs to do it
  • 4,472 Answers
Hi, this is a manufacturing defect that is very common in these imacs. How long ago did you purchase this imac. Some of them have fallen under extended warranty due to to it being apple's fault for the defect but I believe that program closed near the end of 08. I would call apple directly and complain about the issue and they may fix it at no cost to you. A work around to the problem is to hook up a secondary monitor and use that as the main monitor. Due to this being a defect in the LCD screen itself it is not worth repair as it could easily run 700-900$. I would recommend just using a separate monitor. This is a huge widespread problem, so I would complain to apple anyways as it is unacceptable to leave consumers hanging because of their defective manufacturing. If you need any further assistance please let me know.
Thank you,
Lee
Posted on Aug 21, 2010
  • Lee A.
    Lee A. Sep 05, 2010
    That is very good to hear, if you have a moment please take the time to give me a positive rating.
    Thank you,
    Lee
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
White lines on screen
It is a problem in the vertical circuit of the set---most likely a bad filter cap connected directly to the vertical output IC chip.
It may be a do it yourself repair if you are handy.
Let me know if you have questions.
SD TECH
Jul 24, 2010 | Toshiba 32A33 32" TV
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Thin white horizontal lines have appeared on the upper quater of the screen. Under these lines a greena red line has appeared. Bottom three quarters of screen is good.
u have to change a capacitor(470mfd or 100 mfd) in vertical section of u'r tv circuit board..if u r a tech person try this...
Jan 26, 2010 | RCA F27442 27" TV
Vertical lines appearing on my laptop screen
...not good. Generally means your screen is on it's way out.
Jun 22, 2009 | Compaq Presario M2000 Notebook
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Apple iMac G5 Desktop Logo
79 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
