Question about RCA P55000 55" Rear Projection Television
The television just starts changing channels and the volume goes all the way up. We have no idea how to fix it...can you help?
    Problem Solver:
  • 9 Answers
More than likely your tact switches are sticking in the little circuit board on the front of your unit. If you unplug this circuit board and the problem is resolved then you know it was the culprit. The unit should still work via remote while you have the board rebuilt. It unplugs from behide the screen near the back of the crts on most models. If problem persist with brd disconnected then its probably the eprom.
Posted on Aug 21, 2010
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Jan 09, 2013 | LG 42LC7D-UB Television
The volume goes to 100% and will not lower by remote or using the volume button on the TV. If I use the up button to change the channel I think it was turning volume up. How can I fix this and will it be...
It could be the volume up tact switch is stuck thereby needing replacement. I cant help further without knowing the model number but www.tvrepairworld.com should be able to provide free tech assistance as well as any replacement part you might require.
Jun 01, 2012 | Televison & Video
Everytime I change a channel on my LCD Tv Hi Sense 32
If your using front button to change channel then try to use remote..
If on the remote is fine then the button board of your TV got faulty usually it cause bad contacts of button (vol+,vol-) so that if you press any button the volume button activated due to auto contact..
You can replace the button or replace new button board assembly..
Dec 24, 2011 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Mar 22, 2008 | Philips 32PF5320A 32 in. LCD Television
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
