Question about Samsung SWA-4000
It keeps saying "rear check" on the display. and i have reset everything and it doesn't connect to the rear speakers. the 3 front speakers will work just fine and thats with the sub. what do i do to fix this?
Best solution - DON'T BUY SAMSUNG - every thing I have ever owned that is SAMSUNG has gone wrong (TV's, surround sound, blueray, microwave, you name it it's gone wrong!)
Posted on Aug 21, 2010
I am having the exact same issue..
it kinda defeats tge object if I then have to connect the rear speakers direct wuth main unit as its no longer wireless!!
Grrr
I kinda disagee..I have 2 Samsung tablets and 3 Samsung mobile phones as well as a 55 inch Samsung TV which all work perfect!!
Posted on Oct 27, 2014
Stereo wiring diagram for 2005 Chevy trailblazer
Hi there:
Check this on 2005 Chevrolet Trailblazer Car Stereo Wiring Chart...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 25, 2012 | Cars & Trucks
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
The Denon does not play any source on the speakers, just on the headphone jack in the front. What could be the reason?
You might want to review the manual below:
http://www.usa.denon.com/AVR-1908-OM-E_109.pdf
1) Make sure MASTER VOLUME is not set too low 2) MUTE should be OFF 3) Make sure nothing is plugged into the PHONES jack 4)Make sure the source program has a signal present - the inputs may not be connected to the selected source on the front panel (or try FM or AM for a source instead) 5) Check for proper connection at each of the speakers AND at the rear of the stereo. 6) Perform a microprocessor reset: a.Power the unit off, b. Press and release the "POWER" _while_ keeping both "Speaker A" and "Speaker B" buttons pressed. Once the display begins flashing in 1 second intervals, release both speaker buttons.
Hopefully, one of those steps will solve the issue. Please rate this reply if it was helpful - good luck!
Jun 30, 2010 | Denon AVR-1908
No sound from front center and rear speakers on my xv-dv55
Hi
1st check your cables are inserted into the subwofer (which is the powersource)
however it sounds as though you have switched the player to mono mode to reset it try this
2. On your remote press the system button with the green ring around it 3. Then press the dts button (number 7) keep pressing it until the auto option appears (watch the little black display screen)
hope fully that should fix it
I am assuming that you no longer have the manual other wise you would have checked in there? But if you do and this does not work try read the first few pages on setting up the sound for your system.
Lou
Apr 05, 2010 | Pioneer DV-340 DVD Player
Sony STR DE845: rear speakers not working, three fronts are OK.
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Sep 05, 2009 | Sony STR-DE845 Receiver
My back speaker doesn´t work,, everything is
It sounds like it's your radio if it's the OEM. To make it somple the factory radio had there separate amp muilt in each chanel so if one speaker went bad the others woudl still play. There is no quick fix other then haveing it replaced or if have it repaired.Good luck and just dubble check all the connections
Apr 08, 2009 | 2004 Dodge Durango
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Altec Lansing speakers in laptop
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Jan 14, 2008 | HP Pavilion dv6000z Notebook
Samsung SWA-4000 Logo
532 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
