Question about Mitsubishi WD-73733 73" HDTV
My Mitsubishi WD-73733 won't turn on. It started with a noise as it started up, coming higher on pitch and then lowering it, and doing this three times. Red light will turn on. So I purchased a new lamp. Installed it (got audio to begin with), but the same thing happened. I'm getting an error code 66 with both the old and new lamp. Any ideas?
tvtek
  • 1284 Answers
SOURCE: need to align my mitsubishi wd-73733 dlp tv
We TV technicians don't go into alignment unless absolutley needed. I would stray away from alignments period unless you understand all of the ramifications that come with them.
Posted on Jan 08, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: Humming noise when TV is on and off for 15seconds
Maybe it's a fan?
Posted on Jun 26, 2009
saidneurot
  • 128 Answers
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
Posted on Dec 18, 2009
  • 160 Answers
SOURCE: how to change lamp in mitsubishi wd 73733
Your TV is so-called V-36 chassis.
First shut off TV and unplug it from the wall.
On the back of the TV on the right hand side if look from behind you can locate plastic lamp cover that is removable. Behind the cover you will see lamp cartridge that held in place by screws that you have to loose using screwdriver. Remove lamp assembly and install the new one. Make sure that cartridge is all way in, you have to feel connection plug to be slide-in all the way. Tighten up screws but not too hard.
Reinstall lamp cover. Plug TV into the wall and wait for green LED light to stop blinking. Turn TV set on. It should display message "Power loss, did you replace the lamp?" You hit "enter" on your original Mitsubishi (not the cable box or Satellite box) remote control and this is it.
Regards.
Russ.
Posted on Apr 07, 2010
Mitsubishi WD-73733 green blinking light will not turn on.
This is know as the blinkling light of death. You can get parts - just google TV Repair Kits
Mar 26, 2012 | Mitsubishi WD-73733 73" HDTV
My mitsubishi wd 73733 just made a popping sound and went off.when i tried to turn it back on its making noises with no picture goes from a green light to blinking red on lamp inicator do i need a bulb or...
You can actually go with just buying a bulb. I have seen many cases where televisions stopped displaying a picture due to a worn out bulb. The noise is also from the weak bulb.
Mar 13, 2011 | Mitsubishi WD-73733 73" HDTV
Want does yellow light mean
If I'm not mistaking I believe Mitsubishi shows the yellow light to indicate new bulbs needed and or overheating. Most common is overheat, but may actually be a bulb replacement required.
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73733.pdf
That is the manual for your TV
Mar 10, 2011 | Mitsubishi WD-73733 73" HDTV
Where can I buy and how much is a light engine for wd-73733 73" mitsubishi
Mitsubishi parts can be purchased at authorized service centers for around $450. Other distributors may carry Mits but the price will be higher. Part number is 938P019010. We are also a Mits authorized center. Thx
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD73727 73" HDTV
TV will not power on, strange arcing and poping noise from rear
Even though the Lamp looks good it does not mean that it is. The only way to know is to relace it. If you have already replaced it with a Mitsubishi Lamp Assy. then the Ballast board would probably be the cause.
Hope this helps,
Skyassoc
Jul 04, 2009 | Mitsubishi WD-73733 73" HDTV
Need to align my mitsubishi wd-73733 dlp tv
Jan 08, 2009 | Mitsubishi WD-73733 73" HDTV
Mitsubishi WD-73733 73" HDTV Logo
285 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
