Question about Dell Dimension B110 PC Desktop
I have a Dell Dimension B110 and it only detects 256 mb. I have installed a WD 500GB hard drive and installed 2 - 1 GB RAM and still nothing. I think I need to change the BIOS but don't know how.
  • 596 Answers
Yes, you need to change your bios setting. The best thing to do is the reset the BIOS to default and check your system after the reboot. Good Luck
C2S.
Posted on Aug 21, 2010
  • jtwcnr Aug 21, 2010
    I cant find the default/reset for the bios in the system start up. I don't have an OS installed yet(trying to get windows 7) so i didn't know if that makes a difference or not.
  • Nouveau IT, LLC
    Nouveau IT, LLC Aug 22, 2010
    jtwcnr,
    Sorry it took so long to respond. I have tried finding info about your BIOS setting and have not had any luck. (Even from Dell) Did you have an os on the pc before? I did notice that the spec for your pc hold a max of 2GB RAM. The other thing is up to 64MB of RAM will go to your video card.
    If you able to see your memory specs in the BIOS setting, (under Memory Information tab/section, it should let you configure speed of your memory. I will continue searching for reset info about the BIOS. Please update if you run into further issues.
    Best Regard,
    C2Solutions
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
OR
Find the drivers for sata device and install
Feb 20, 2009 | Mercury KVM800M Motherboard
Replacing RAM in Dell Dimension 3000
Upgrading RAM will not affect your files. Just make sure you upgrade with compatible RAM & that you install it in pairs. So if you want 2 GB then you would want to be 2 x 1 GB RAM chips. Hope this helps & please remember to rate my answer. Thanks.
Feb 02, 2009 | Dell Dimension 3000 PC Desktop
I replaced a bad 120 gb hard drive with a WD 500gb sata hard drive. Installation went fine, however I am having trouble with the reinstall of the XP system. It freezes up at the point where it asks if you...
First, I would remove the 120 from the system during installation. If possible, use a Windows XP disc w/ SP2 to speed up installation of the OS. Plus SP2 handles a maximum disk size error which limits you maximum partition size. (Under SP1 I think the largest partition can be 137 MB)
I would recommend using NTFS format for the hard drive.
Once it is installed, you can always re-connect it to simplify the installation.
If it's still freezing, check the disc for damage or defects.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension B110 PC Desktop Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
