Question about Kitchen Ranges
WE HAVE A KITCHENAID STOVE THAT KEEPS SHUTTING OFF WITH A CODE OF E2F5
    Genius:
  • 1,073 Answers
Check the door latch switches
Posted on May 03, 2008
Kitchenaid stove code f68
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
800-422-1230
Jan 03, 2014 | KitchenAid Electric Stove Range...
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid stove spark ignitor keeps sparking
there must b some problem with ur ignitior u must replace it.
Jul 21, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
The heater keeps shutting off , getting a 99 code
Terry,
Remove the flex hose from the flue pipe inside the house. Try to start the stove. If it runs there is a problem with the flue. If it's been very cold look closely at the pipe around the exhaust pipe. That is the air side. There could be frost built up inside the air pipe. If so it will shut off the gas and you can't run the stove.
Tom Hawkins
hawkins111@gci.net
Jan 31, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
UNLOCK STOVE DOOR
no code for unlockin door, were you self cleaning unit prior to door locking? if so themal fuse problably tripped off for percieved saftey reasons( thought it got too hot), you might be able to jimmy door open witha wire hanger bent a 90 degree angle maybe 2 in long slide it between console and door latch should release to the left. good luck fishin!!!
Feb 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
