Question about Indesit Washing Machines
Indesit wixe127 displaying f-12 - Indesit Washing Machines
barkencoa
  • 3463 Answers
SOURCE: Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Posted on Nov 21, 2008
  • 14 Answers
SOURCE: indesit wixe127 error code F05
I removed the drain pipe and ran the wash cycle into two buckets which completed correctly.
I therefore checked the drain connection to the sink and found a lot of fluff blocking up the hole.
The fixya guru suggested it could be pump and / or pressure switch but it was much simpler than that.
Us engineers often dive in at the deep end with technical fixes but sometimes the solution is simple.
Posted on Jan 17, 2009
lenwest
  • 150 Answers
SOURCE: Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Jan 31, 2009
barkencoa
  • 3463 Answers
SOURCE: error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Posted on Dec 02, 2009
SOURCE: indesit wixe127 f-08 error
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Posted on Feb 24, 2010
Display is flashing and cracking noise coming from my indesit wixe127
could b bearings or may b electrics need more info on cracking
Apr 13, 2015 | Indesit Washing Machines
Error code f-05 on idesit wixe127
F05: Pump Blocked or pressure switch empty not reached
- Check efficiency of J9 connector on card, verifying a voltage of 220V between pins 8 and 9
- Check that pump if being fed
- Check Pump Filter + wall drain
- Change Pump
- Replace Card
Dado
Feb 28, 2015 | Indesit Washing Machines
Indesit WIXE127 washing machine with a flickering display screen
This is a fault with the contoller board and it is possible that the power supply is not stabilising due to an erratic stabilisation. This can be due to faulty capacitors- in case the main filter had leaked and damaged.
If so you can replace them but with case to remove from the PCB.
Also it can be due to poor connector or dry solder on the main board. Best is to check this out without delay as it can damage the board at a later stage..
Jun 26, 2012 | Washing Machines
Indesit wixe127 f-08 error
Feb 07, 2010 | Indesit W 123 Front Load Washer
Error code f-08 on indesit wixe127 washer
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Wixe127 indesit wash machine gets to 1 minute left on wash cycle and just keeps running with 1 minute on display
If all you are getting is a wash cycle and not a spinning cycle this could indicate a faulty door switch. the machine will not allow a spin cycle unless the door is locked.
Oct 10, 2009 | Washing Machines
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Hi.
Cheers.
Nov 18, 2008 | Washing Machines
Hi i have a indesit wixe127 and when i switch it on it comes up with deno and will not wash wot is wrong with it
I had the same problem with DENO, while we run the wash machine i press start button and step easier(try the start button and click buttons simultaneously until the code DOF) button until DOF code came, after everything went well. e.ladislau@yahoo.com
Jun 19, 2008 | Indesit Washing Machines
Washing Machines Logo
437 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
