Question about Kenmore 500 6952 Dryer
Can my heat sensor be replaced by myself or do I need to call a technician?
    New Friend:
  • 35 Answers
It depends on if it is a heat sensor or a thermal fuse or even something else.
I would need to know what your dryer is "doing" or "not doing"
If you are sure of the part already; sure you can do it...but...
I recomend you:
1) Unplug it
2) Clean interior of all lint
3) Clean lint out of exhaust chute
4) Check for any breakage or parts laying on interior bottom
5) be careful when restarting to test as follows:
A) stay clear from dryer
B0be ready to shut it off quickly in the event of a problem
Good luck,
Vinnie
Posted on Sep 13, 2010
Engine Service Soon Light On code P0154
Error Code: P0154
Description:
Heated Oxygen Sensor (HO2S) 1 , Bank 2 - No Activity Detected
Problem areas:
- Wiring.
- Open circuit in signal wire, between Heated Oxygen sensor 1, Bank 2 and ECM. (Must check and confirm)
- Heated oxygen sensor (HO2S).
- Engine control module (ECM).
Nov 20, 2013 | 2003 Mitsubishi Montero Sport
Where is the fan sensor located on a 2001 Saturn? Mine needs to be replaced and wanting to do it myself
when you say fan sensor-are you talking about the radiator fan or the blower for the heating and cooling system?-Denny
Nov 08, 2013 | Cars & Trucks
Heat pump Trane XE1000 needs new condensor motor and run capacitor
you could replace it yourself remove old mtr & cap. info. you need should be on body of each if not check unit call supply stores or local company for parts
Mar 22, 2012 | Heating & Cooling
WHAT IS THE HEATED OXYGEN SENSOR BANK 1 SENSOR? WHERE IS THE SENSOR HEATER? CAN i FIX IT MYSELF? ALSO,,, EGR SYSTEM FAULT,,,WHERE IS THE PRESSURE SENSOR? CAN i fix it myself?
Oxygen sensor bank 1 is the first sensor in the exhaust system. It should be located between the exhaust manifold under the hood and the catalytic converter. The one after the catalytic converter is the bank 2 sensor. The sensor heater is located in the sensor itself...it can only be replaced as a whole. You should be able to change this yourself with the correct size wrench... just unplug sensor, loosen and remove. Replace with new sensor the same as removed. This could be causing the egr system fault as well.
Jul 10, 2011 | 2003 Buick Century
Tappan gas range model 30-3991-23/03 - when the oven is heating, an F3 code comes on, followed by an F2 code. The oven turns of and I can't heat it again until it has cooled. Can I repair it myself? ...
Hello & Welcome to FixYa
F3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 15, 2011 | Tappan TGF320 Gas Kitchen Range
Install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Nov 05, 2009 | Carrier Heating & Cooling
How to replace an oxygen sensor bank 1 and exhaust gas recirculation sensor
The EGR valve is attached to the intake manifold near the throttle body and the 1/1 O2 sensor is on the rear exhaust manifold.
May 02, 2009 | 1997 Dodge Caravan
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Goodman PGB042100-1 REVA Flame sensor not working; no heat
try national energy they will give you a price you will need make model and serial number 600 is high you should be able to get it for a lot less
Jan 07, 2009 | Goodman GMS90703BXA Heater
Intermittant heating
You probably have a new unit by now. The Magnetron part inside usually is the problem with this Maytag unit.I have had this unit blow the 'Magnetron' four times ! Everything else works fine. After watching the technician, I replaced it myself the other 3 times. The whole unit has to come out of the wall to do this. This High Voltage part is dangerous. The part costs about $100.00 from an online parts store. Partselect.com- or someone else.
Jan 05, 2008 | Maytag MMV5156AAS Microwave Oven
Kenmore 500 6952 Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
