Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool gold 2007 side by side refrigerator. Ice won't drop. Agitator doesn't spin. Makes a groaning noise, but agitator bar/motor doesn't drop ice down the shoot. Water dispenser works fine. Makes plenty of ice.
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
dididsaythat
  • 291 Answers
SOURCE: Whirlpool side by side GS6NBEXRS01
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Posted on Aug 29, 2007
dididsaythat
  • 291 Answers
SOURCE: Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Posted on Sep 08, 2007
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
SOURCE: Whirlpool Gold Ice dispenser problem
i had same exact problem, i search over and over for solution. I even change the auger moter.
here is the solution for this particular problem.....
with the fridge door closed, remove bottom catch tray under ice dispenser revealing two screws, take off screws and slide front trim up to remove, you will have to unplug switch on trim to fully remove, look in top right corner there is black switch the will most likely be loose, this switch is your problem, mine was basically dislodged and the ice dispenser lever was not making contact, i simply zipped tied and siliconed the switch back to its respective place. if yours is making a good connection then the switch its self must be bad, you can test the switch by using the switch from water dispenser side...
i hope this helps
Posted on Oct 01, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
Ice dispenser runs, but agitator in ice bucket does not turn.
there is something wrong with the tip have somebody look at it here is somebody go to thehandyhandyman.com they will be glad to look at it for you
Dec 26, 2008 | Whirlpool GS6NBEXR Side by Side...
Agitator doesnt work
soundslike a bad motor coupling, part number 285753a, this machines equivilent to a belt, videos are on you tube to walk you right through repair, easy enough!
Dec 08, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loud grinding noise from agitator. How hard is this to fix.
Removing the agitator will not stop the grinding noise. Usually a bearing/gearbox problem going bad will create a howling grinding noise. You'll definitely hear it in the spin cycle. These are an expensive fix and require special technician tools to disassemble the unit. The gearbox is a sealed unit. Most manufacturers warranty their unit's gearbox for 5 years regardless the warranty you got when you purchased the unit, so check into this before you void your warranty. (The manufacturer requires their factory authorized service technicians to do the replacement) All in all if you do the work yourself it'll be approx $250 for the parts and gearbox transmission. To have the work done is usually much more.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
181 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
