Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My Fisher and Paykel dishwasher will not keep running.
Starts to wash and then just beeps and stops but keeps beeping until I push the power button
  • oc35 Jun 02, 2008
    Our top washer when set on normal no eco (111 minute) cycle will sopt when the tomer shows 97 mins and beep until the start button is pushed the cycle then appears to carry on.
    OC Smith
  • Anonymous Mar 18, 2014
    electronic controls keeping it in rinse mode; then it will finally go into wash when i push
  • 413 Answers
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the door is open or closed. Wipe these areas with a clean dry cloth...Give it a try
Posted on Jun 03, 2008
The diswhasher won't stop running
The motor in the front is the dryer motor. This will keep running until the dry cycle is complete. If it is beeping and there is no other display or light flashing then this motor is faulty and needs replacement.
Dec 15, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Can the beeping alarm be turned off?
usually if you turn the power off and on after a short delay the beep should go away. But the alarm fault code will keep showing on the display / drawer panel light until fault is fixed.
Hope this helps.
Feb 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Control panel or electrical panel not working right. It stops washing at 10 minutes
The DD603 dishwasher from Fisher and Paykel is a very sofisticated electronically controlled dishwasher. It does not have a control panel or electrical panel unlike some of the other brands of dishwasher which are electromechanical controlled.
So if it is stopping with 10 minutes left on the LCD display, then it might have simply gone into the Dry mode. A small fan in the door unit starts up and sends warm air into the unit. At this time the dishwasher gives a couple of beeps. You will have to wait until the time display goes to 00 provided the dishwahser is set to be in the Clean Dish indicator option is on. This means the washing is complete. Refer your instruction manual.
It is also a good practice to keep the area around thw wash program button (on the drawer door top edge) clean. Sometime grime can cause false trips.
Hope things are not as bad as it may appear.
Nov 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 Top washer isn't coming on
is the lock symbol showing in the lcd badge when it's not back lit can be hard to see ,if it,s showing push lock button till it beeps release immediatly now try power button or start/pause button
Jun 05, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
344 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
