Question about Intel D845GVSR Motherboard
Which audio driver for my pc - Intel D845GVSR Motherboard
Audio drivers for compaq presario cq61 model
Compaq Presario CQ61-125EQ Notebook PC - Audio Drivers
  • Windows 7 - 32 bit Audio driver -> Download
  • Windows 7 - 64 bit Audio driver -> Download
  • Windows vista - 32 bit Audio driver -> Download
  • Windows vista - 64 bit Audio driver -> Download
Dec 22, 2010 | Computers & Internet
When i am installingconxtant audio driver it is telling media device not found and not installing
Typically, if you are getting a "device not found" error upon trying to install an audio device driver, there are a number of issues that could be going on at one time.
First: You may have the wrong device driver or version of the device driver for the device intended for. Check the hardware version number and verify on the website of the hardware device (the audio card if it is an independent audio card that is what you are referring to) what is the latest revision of the driver. Download the driver and install it.
Second: If your device is an external audio card, make sure it's fully inserted into the PCMIA slot (seriel port if being used). If so, then accomplish the following procedure: Power down your PC. Remove the Audio Card and reboot PC. Allow PC to recognize no audio card, then shut down PC and reinstall Audio Card. Reboot PC and install with new Audio Driver
One of the two steps above should rectify the problem. If it doesn't, then the last resort is to assume the Audio card is faulty if it's an external Audio card.
If you have an internal Audio card, then there can be a faulty portion on the sound portion of the motherbood, which then would require the entire motherboard to be replaced. But before you result to this, be sure you have the newest Audio driver for the Audio Codec and installed correctly.
Please keep in mind, Conexant is an OEM supported Audio Codec and you need to refer to the maker of the PC itself for driver support. I.E. it may be a Conexant Audio chipset installed in a HP PC. So, be sure you go the manufacturer website such as "HP" for the audio driver support.
Hope this helps,
Jun 26, 2010 | Computers & Internet
Eee PC 1000HA Audio Driver Cannot installed in windows xp
Here is the Audio driver download link for Windows XP
http://dlsvr.asus.com/pub/ASUS/EeePC/1000HA/Audio.zip
if you are able to install the driver.
Install this patch "Microsoft UAA Bus Driver for High Definition Audio"
Here is the link
http://america.giga-byte.com/FileList/Driver/motherboard_driver_audio_realtek_azalia.exe
and installed the Audio Driver again.
Your Sound Card should work now.
Jan 04, 2010 | ASUS Eee PC 1000HA Notebook
Sound driver
Please forward PC 400 mb audio driver alc201a
Sep 28, 2008 | E-Machines eMachines Refurbished EMA...
Audio not working and bought the computer with sound
Audio not working means there must be a driver problem.Try to install the audio driver again.If it is high Definition audio driver first uninstall audio driver and high definition audio driver package.Reinstall the driver again.if problem persists check for the audio port.
Jul 05, 2008 | Acer Aspireā„¢ T180 PC Desktop
No audio drivers
Installing only audio drivers will give you error "DRIVER INSTALLATION FAILED. COULD NOT FIND MEDIA DEVICE FOR THIS DRIVER" .so to solve this problem first you have to download microsoft universal audio driver and then install audio drivers
Audio Drivers
link 1 :microsoft universal audio
ftp://ftp.compaq.com/pub/softpaq/sp32501-33000/sp32646.exe
link 2 :conexant high definition audio
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
________________________________________________________
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
May 21, 2008 | Compaq Presario 700 470024-192 Notebook
Intel D845GVSR Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
