Trane voyager rooftop second stage contactor keeps blowing coil it fries ////after a week or so sometimes longer or shorter wont pull in and seems to weak to pull in but when i put a seperate contactor out of line for test purpose it will pull in no problem
  • 43,501 Answers
One of the safety switches in the control circuit for the secind stage are bad... the contacts are pitted or corroded and are not passing the full voltage through...it will be hard to find the bad one because it will only do it under load...I would start jumping out safety switches for a short time and checking voltage to the coil til you find the culprit...
heatman101
Posted on Aug 21, 2010
Electrical issue When does the K2 heating element contactor pull in?
Likely 2 stage heat. If you raise the temp, say, 10 degrees, it should call for 2 stages of heat.
Jul 24, 2017 | Heating & Cooling
Trane xr90 furnace keeps on running
Well my friend, the thermostat board of land in the interior michanimatos.echei two thermistors, what the problem is the bronze thermistor.take it from there which is anchored in the thick pipe that leaves the air conditioner and is connected to the outdoor unit. check this option if it works and if it works changed the thermistor.
Apr 07, 2012 | DeLonghi Trane 5t Rooftop Air Conditioner...
Electrical diagram for contactor (240 v/1 phase/24 v coil)
How to connect motor 1 phase with mcb , contactor , timer ,switch selector on off on , and lamp indicator
Feb 17, 2012 | Omega Trane Furnace Draft Inducer Blower...
I have a Trane model TWE030P13FBO that keeps blowing the 5 amp fuse tied into the transformer. Just to see if I could solve the problem I put in a 10 amp fuse and the transformer smoked and I'm sure now...
You have a short in the low voltage...it could be the t-stat or the wiring to the t-stat...also could be the coil if a contactor, or a wire rubbed through somewhere...
To find it you need to start to isolate sections of the low voltage circuit and then ohm out each section...problem is that some will still not show up with out power applied... believe me this is not fun and can make ya pull your hair out...be patient and persistent...
but as you found out do not try a higher amp fuse...transformers work on smoke...and when the smoke comes out they no longer work... :-)
heatman101
Sep 15, 2010 | Heating & Cooling
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
My rooftop Trane A/C unit shows high humidity on the thermostat, will not cool the house during the day but cools fine at night. What could the problem be? Also, how can I lower the humidity in the house?
High humidity causes Icing of the cooling coils. Avoid constant running of the a/c. Meaning let the AC pull the house dow 2 - 3 degrees at a time.. The unit shutting off will allow the ice to melt. Make sure the drain is clear by going outside and chkg for drainage. Once the house is reasonably dehumidified the ac can be set and left on its own.
Jul 06, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
The coil has to much condensation, the coil is clean and the drain its okay, also the fan is working okay, I dont know what is the problem
make sure drain has a trap so it wont **** outside air into unit and cause a vaccume in evap. compartment which will cause the water not to run out correctly.
Jul 02, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
A/C blows warm air
The condensate line was filling and the kill switch was turning off the compressors but the blower is not tied in so it kept running. When the water pump caught up it would take five minutes to turn back on and the temperature was roller coastering. They disconnected the kill switch. now I'm watching to see where the condensate will go if the pump can't keep up. I'm not sure for the long term if this is the best solution.
Jun 23, 2009 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
