Question about GE Monogram ZISS480DRSS Stainless Steel
GE Monogram freezing food
Brand new refrigerator that freezes food in the refrigerator section, temps in the 20 degree range. Had two GE repairmen. One just left the other one still trying to fix. If this one can't fix the problem either can you?
  • 2 more comments
  • girardmom May 03, 2008
    Nothing, I just have a bedroom full of parts for this brand new refrigerator. GE can not get the repairman to come back. "He said" he would return this week but that is what he said last week when he never showed up.I don't think he can figure out the problem with this refrigerator. Other than it's just expensive junk. Doing without a refrigerator for over 3 weeks has been rough but getting GE to get this thing fix is a nightmare. I am afraid I'm going to have to figure out how to put these parts on myself and I don't have a clue!!! Oh by- the -way this is the second repairman GE has sent. The first one just finally gave up.
  • Anonymous May 28, 2008
    I have a repairman coming out on 5-29-08 to fix this exact problem. I'll keep you posted.
  • remraf Aug 16, 2008
    We have same model and same problem.  Refrig side is freezing my food randomly.  Temps vary for
     no apparent reason and freezer will not stay really cold.  Also having problem with water overflowing or splashing from ice maker creating icicles on the shelves.
  • MindyT17 Oct 14, 2008
    I have the same problem with my milk freezing! I'm so mad- the fridge is not that old...
I got the same problem.
Temperarily solution:
Open the top hook overnight and you will see the temperature will return to normal i.e. 1 degree F
I suspect there is the thermostat or some type of thermal sensor that prevent the freezer to operate during summer time
Hope it help
Posted on Jul 28, 2008
    Genius:
  • 1,073 Answers
What have they replaced so far
Posted on May 03, 2008
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Frig is getting to cold and freezing the food. temp set at 40 and stays at 28-30 degrees
Check to see if your dampers are working. They open and close based on the temp.
Kit Damper Number: WR02X11241 Substitution: WR49X10107
Jan 30, 2011 | GE Monogram ZISS420DRSS Stainless Steel
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISS420N - Freezer works fine - refrigerator side is also freezing with thermostat set on 45 - repairmen (if you want to call him that) on five seperate occasions replaced thermostat,...
We are GE Monogram factory authorized service & parts and this issue sounds like your control board to your fresh food has gone out. The control board controls all the parts on your GE Monogram. You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance service issue and to get your parts.
We hope this solves your issue and we look forward to working with you.
Nov 07, 2009 | Refrigerators
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
GE Monogram ZISS480DRSS Stainless Steel Logo
475 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
