Question about Canon ZR40 Mini DV Digital Camcorder
After using approx 20% of a cassette while on vacation, I tried to view what I recorded upon returning home. I kept getting, and continue to get "Remove The Cassette" message even when inserting a brand new cassette, and am unable to view or record. Please advise.
  • rredvet Aug 21, 2010
    Exactly, what is a PCB? Where is it located? Ribbon like connector? Opening it up, does this mean opening the cassette enclosure, or does it mean dismantling the video camera? Insulation on all ,the connectors, does this mean where all the cords plug into?
  • 4,889 Answers
This problem is caused by a loose ribbon like connector on the main PCB. When a friend of mine had this problem, I opened it up, unplugged and re-plugged all the connectors, re-assembled and turned it on. Worked like a charm for about 2 days when the problem re-appeared. So I have opened it up and put insulation tape on all the connectors and problem has not appeared ever since. Apparently this is a very common problem on canon camcorders. Some people even reported that bashing it fixed the problem!
http://www.fixya.com/support/t129385-remove_cassette_displays_when_put_in
Posted on Aug 21, 2010
  • eagle338
    eagle338 Aug 21, 2010
    Yes you have to dis-assemble the camera. The insulation tape is just to hold the connectors in place and prevent them from loosening. Its not an easy job but if you want to do it yourself, then I am here to see you through this.
After running approx. 25 tapes the player stopped working
Hi Ian.
Judging by reviews on Amazon, you're not alone in having trouble with the cassette player, which has multiple people decrying the quality of the unit
Audio Recorder 3 0 Plus with Cassette Player
That said, if the player hasn't just had some sort of internal mechanical failure, I'd recommend opening it up and gently turning the tape capstains with your fingers to see if they'll move. Try turning the player on with the door open but no tape inside to see if anything even spins. If there's been a mechanical failure, you're likely out of luck - cassette tape decks these days are getting rarer. If you're lucky, perhaps a bit of tape or some other debris has jammed up one of the capstains. In that case, you may be able to clean it up and see if it works then. If you've gone through the tapes fairly quickly, I'd suggest just returning the unit (your credit card likely as not has warranty-extensions built in if it's close on the warranty).
There are other tape decks out there, with a wide range of price, and, likely, quality, with USB out to let you play tapes to your PC. You may be able to use other options from there to get your tapes transferred.
Amazon com cassette player with USB out Software
Hoping this helps. Happy Holidays
D
Dec 14, 2015 | Honestech Audio Recorder 3.0 Plus W...
What a cheap machine. Can't erase confidential tapes after transcribing them. I'm returning this for a brand that has enough common sense to add an erase button.
Hello unfortunately this unit don't have a erase function the only thing you can get a Microcassette eraser this eraser will help even if you decide to buy any micro or mini cassette transcriber when you used the erase function on the unit the life on the head, rewind, gears and motors get reduced by using this method if you used and eraser it erase the tape Magnets are on top and bottom eliminating the need to flip the tape allowing complete erasure on one second heare is a eraser you can buy and it is cheaper than buying other unit. http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx
Nov 22, 2010 | Sony M-2000 Desktop Cassette Transcriber /...
Returned home from vacation. Had been lightening
panasonic KX-TG5632
No dial tone ,no link to the base,move closerto base,try again
Dec 02, 2009 | Panasonic KX-TG5431 Cordless Phone
Purchased Canon FS-20 camcorder last week to take on vacation to Disney World. Used it first day for 3 hours off and on then got error message: ''Cannot access internal memory''. Will not record even with...
I've got the same problem, also with a brand-new Canon Legria FS 20. As Canon told me, I took it to a Canon office to be repaired. It was repaired. I tried filming and it worked. Then I tried to view this film and I got the same error message again: cannot access internal memory. I also can't film anymore now. I'll call Canon now and ask them what to do. Repairing didn't help, I want a new cam, but I'm not sure the FS 20 is a good choice. There seems to be a problem with it.
Jun 08, 2009 | Canon Video Cameras
When on vacation you can't go anywhere
are you using windows xp or vista on vista this happens
Jun 07, 2009 | Electronic Arts The Sims 2: Bon Voyage
Limited recording time
WS-100: 64 MB
HQ mode: Approx. 4 hours 20 minutes
SP mode: Approx. 8 hours 40 minutes
LP mode: Approx. 27 hours 20 minutes
You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
SONY MP 120 8mm video cassette
Problem is dirty / clogged video head of v-8 player or camcorder what ever you are using for playback. Use good quality video head cleaning cassette for head cleaning.
Please check tapes on another camcorder as tapes seems OK.
Oct 22, 2008 | Sony 8mm Stantard Grade 120 Minute...
Samsungscd23/blank viewscreen for photo memory stick
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Aug 01, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Canon ZR40 Mini DV Digital Camcorder Logo
47 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
