Question about Home
I have a 1990 chevy s-10 4.3 v6.some one put an rv cam in this motor and set the ignition timing way to high it was off the time marks,when i shoot a timing light on it the line was on the passgner side,whts the correct ignition timing for idliing timing and total time
  • 707 Answers
If you put the #1 pistion up top dead center and the timing marks are aline you will be able to adjust the distribuator in line with your #1 pistion to get you goen.............Adjust the distribuator to give max power to the vech while in drive and holding the break with acceleration with safety in mind..........Mhen max power is felt at its best then use timing lighe to fine tune........Hope this helps.
Posted on Aug 21, 2010
I have a oz xe 4.1 lt 250 xflow motor which i have rebuilt and put flat top pistons in bored out 60 thou shaved yella terra head 15 thou and has a very mild cam after lining up timing marks the inlet
when setting up the valve timing it is always done on the exhaust stoke.. Place the piston on TDC and set the valve timing so that the exhaust valve is just closing and the inlet is just opening. Rocking the crank a bit before tdc to a bit after tdc will produce a movement where the exhaust starts to close as the inlet starts to open. This is known as valve rock or valve overlap. The cam modification is of no consequence as the as all that is modified is the valve duration , not when they open or close. With the cam now timed to the crank turn the crank 180 degrees and set the ignition timing to the degrees advanced recommended ( 10-12 degrees bftdc is recommended for starting). Place the HT leads in the correct firing order and when running use a timing light to adjust ignition timing. If you are fitting a new cam then you must bedding in grease and when the motor starts it has to be run at around 2.000rpms for around 10 minutes to set (harden) the cam lobes or else they will wear off very quickly.
Sep 28, 2014 | Cars & Trucks
Why is my 1990 grand am 3.2 v6 sputtering and back firing after I changed timing chain
you must of not put the chain on right. to set it right you must have the number one pistion at the top of cylinder on compression stroke. then line up your timeing marks on the cam shaft then put on the chain.
Aug 10, 2014 | Cars & Trucks
Diagram for engine timing for a 3100 Chevy V6
It's on TDC so align marks on cam shaft and crank shaft with center of cam & crank shafts and the ECM will go from there. so you will have to change the timing chain if its loose or worn out.
May 08, 2014 | 1997 Chevrolet Monte Carlo
Have rebuilt motor new everything from mazda now i have pooo12 code retarded intake cam checked timing with sst and ex and in cam are in perfect alignment with sst the solniod tested out fine . the only...
remember 1 thing..dont confuse cam timing with ignition timing also if the belt or chain has alignment dots or marks on it ..it can be put on backwards and still line up marks correctly but but in a different position making the cam timming off i have done it and seen it done before like an old chevy when you put timming gear set on you line up the 2 dots alot of people think that is tdc and they set up ignition and go to start it and get pops and bangs well thats because the the install dots are actully 180 degrees out from tdc so you remove the distributor and turn it 180 deg. and now she starts right up i think you have 1 of these cams a tooth off or your using marks incorectly or belt or chain is backwards making dots align in different postion appearing correct
Oct 02, 2017 | Mazda CX-7 Cars & Trucks
Will a broken timing belt damage the valves in 1990 toyota camry v6 dx
No damage will occur. This is a non-interference engine so all you will have to do is make sure the timing marks on the cams and crank are set properly.
Jun 09, 2011 | 1990 Toyota Camry
How do i set the timing in my 95 sonoma with an older carberated 350 from start without taking timing cover off?
There are two kinds of timing, cam timing, and ignition timing. You don't adjust cam timing, it is set when the timing chain is installed. The timing chain cover is supposed to have a pointer welded to it with marks that line up with a mark on the harmonic balancer. (depending on the year of you engine these marks veri in appearance. Ignition timing is set while the engine is running with a strobe light that is triggered by the number one spark plug. On this engine (if it's stock) around 8-10 degrees BTDC. The ignition timing advances with cetrifical weights inside the distributor as well as a vacuum diaphragm. If either of these fail you will have a performance issue with a lack of power, and acceleration. If you are concerned about the cam gear being worn out yes they do wear out. Chevy made the gear teeth on the cam gear out of nylon to make then quieter, the replacement gears are usually cast iron. If you are thinking about changing the timing gears, the crank gear has to be pulled off with a puller, a lot of guys don't bother since it doesn't wear like the cam gear.
Jan 26, 2011 | GMC Sonoma Cars & Trucks
I need to know how to fix a timing chain on a 1990 v6 3.1 chevy cavalier and do the valves get messed up when it breaks?
remove everything in your way to get to the cam timing housing cover in front of the block. Set #1 cylinder to dead top center. install new chain or belt...put it back together and litely loosen the ditributor to adjust for timing...once timing is set hold ditributor and tighten bolt. Shut down and recheck timing with the light.
Oct 13, 2009 | 1990 Chevrolet Cavalier
Need firing sequence and diagrahm chevy s10 v6
I take it the dist was removed, if not then your problem is probably not ignition timing
Oct 10, 2009 | 1996 Chevrolet Blazer
Trying to set the timing on this car with a new engine,please help.
timing belt replace v6 engine turn the crankshaft clok wise slowly and make sure that nothing is stoping it for turning, until the key on the mark reach 12 o clok (TDC) the piston no 1 is att the top dead center .if the piston stop before reaching the top dead center ,,,,,one valve or two are open and the cam have to be ajust so dhat valve can close up,,,,,, so after the crank alignement ,the two cam marks at LEFT CAM 2 o clok right cam10 O CLOK ,,,note the belt slack must be on the tensioner side
Aug 03, 2008 | 1990 Lexus ES 250
Home Logo
53 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
