Question about Vacuums
The agitator brush does not work. - Vacuums
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567714
Generic problem for all Vacuums
posted by pastoringram on May 03, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Generally the brushroll is driven by a flat or round belt under the bottom plate and the belt my be broken and is in need of replacement. The average belt change is every 4 to 6 months for the best cleaning on a flat belt, and on a geared belt it should be once a year. So if you are still having problems with the brushroll/agitator that we need the brand name and model # of the vacuum cleaner in order to tell you where to get the belt for the vacuum. Feel free to check with your local vacuum cleaner dealer in your area or contact the Brand Name Factory phone #.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 27, 2008
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
Agitator wont turn
It could be one or more of a few causes. Easiest to check is the belt and/or brush roll. There are two switches for the brush roll. Both must be working properly. One is by the main power switch and the other is in the motor compartment. If the problem still persists check the brush bar motor in the power nozzle assembly
Feb 23, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Model UH70086 agitator brush won't rotate. the belt is fine and turns the wheels. replaced v belt because I thought it was stretched but new belt is the same size. everything turns, the belts and the...
The brush has to be able to rotate freely in order to work. If you remove the roller and its end caps you may find it is clogged with hair or other debris. Cleaning out the debris should allow the brush to rotate freely.
Nov 05, 2013 | Vacuums
Cant figure out how to replace belt
Hi Sylvie,
It is fairly simple to change a belt on a vacuum. I'll explain.
First, Turn the vacuum upside down with the handle in the locked position. Remove the plate on the bottom. Sometimes it's held on by screws, sometimes by clips which you should pry off with a flat blade screwdriver and sometimes you can take them off easily with your thumbs.
You should be able to see the agitator brush and belt now. Use the straight screwdriver to take the brush off. Now you can slip the belt off. Clean the inside and the agitator brush.
If you have a new belt, slip it onto the motor, then onto the end of the agitator brush making sure the belt is tight. Replace the brush and give it a sping a couple of times to make sure the belt and brush are both on properly and all are working. Put the bottom plate back on.
Hope this helps. If it does, I'd surely appreciate your vote. Thanks for visiting with us.
Handie Andie
Apr 12, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Agitator doesnt turn
There is actually a reset button on the agitator, I would try pushing this switch first to see if this fixes it. The button is located on one of the sides of the agitator housing, I'm not sure if it's the left or the right side, or on the top of it.
Look on the sides of the part of the vacuum that is on the floor and see if you can see a small red pole on either side. If you can't find it here, look on the top of the part of the vacuum that touches the floor for a brush overload reset switch.
Try pushing that poll whenever you find it. This switch is a protection mechanism that will shut the brushes down to protect them if something gets vacuum up inside of the brush, it will automatically shut itself off to prevent any damage.
Simply push this overload switch down, and this should hopefully fix your problem.
If this didn't, please let me know and I can walk you through some more advanced troubleshooting.
If this was helpful, please be so kind and rate my repair, or leave feedback.
Thank you!
Chris Jones
GoVacuum.com
May 18, 2010 | Kenmore 31913 Progressive Direct Drive...
BRUSH DOES NOT RUN
If the vacuum's motor doesn't make a noise when you turn the machine to the carpet setting, this means that most likely you vacuumed up something into the brushes that got stuck, and caught the reset switch to trip. Recline the handle down to the floor, and look at the top part of the agitator brush housing (the head of the vacuum that is on the floor) for a red colored pin. Push this pin down with your finger, and try the vacuum again.
If the lower motor however DOES come on, but the brushes don't spin, this is a clear sign that your agitator belt either fell off, or broke. If you remove the 5 screws on the bottom of the power brush, and separate the black lower housing from the top agitator housing, you can access the belt and brush.
Here's a link to the belt used on your vacuum cleaner, which is actually made by Electrolux for ProTeam:
http://www.amazon.com/Electrolux-Power-Brush-Geared-Uprights/dp/B0017PSHDO/ref=sr_1_1?ie=UTF8&m=A13YM4FUDXTJG6&s=generic&qid=1273709439&sr=1-1
I hope this was able to answer your question. If for some reason these two solutions didn't work, please just reply to the repair by using the comment box, and I'll be more then happy to answer any follow up questions.
If this was helpful to you, please be so kind and rate my repair, or leave feedback for me. This is really appreciated by the Fixya community.
Thanks so much!
Chris Jones
GoVacuum.com
May 12, 2010 | Proteam Cascade 14XP Bagged Upright Vacuum
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Healthy Home Agitator Brush Switch
you might have a bad belt ,could be stretched .but if its new i would take it back to where you bought it.it should still be under warranty
Mar 29, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
My vacuum does not have any suction, and it spits out dirt when I roll it backwards. It is an upright Hoover Elite
Trouble Shooting guide:
1. Check to make sure that your agitator still spins. (Agitator = brush). If your agitator does not spin, it could very well be a belt gone bad and means there will be no suction.
2. If belt is fine and agitator spin, your vacuum could be clogged. A clogged vacuum can be cleaned with a brush inserted into the hose of the vacuum to pull out the debris.
Mar 07, 2008 | Vacuums
Vacuums Logo
184 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
