Question about Precor 9.21 Treadmill
Precor 9.1 won't turn on, outlet is good. (When unplugged, switch is OK & stays in on position. Once plugged in, switch flips off and won't stay on.) Site wouldn't allow me to choose correct model - this is a 9.1.
I'm guessing the internal fuse is blown, which is part of the safety feature when you pull the magnetic key off. You need to put the little magnetic key onto the "stop" area after each use, and it will re-set. If you take the key off "start" and the machine stops, you can't start again until you put the key on "stop". Once you do that, the main switch should work again.
Posted on Nov 11, 2010
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
PRECOR C956 power switch wont stay on
The power switch on Precor treads is also a circuit breaker. If it trips when plugged in, you have a dead short in the machine.
Feb 06, 2014 | Precor Exercise & Fitness
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Precor 9.25i treadmill will not turn on at on/off switch. It throws a spark then immediatly turns off
With a few more details I am sure we will be able to work through is issue together and get you back into your exercise program shortly. If you would please give us a call at 1-800-347-4404, one of our technicians will be more than happy to assist you. Please give us a call at 1-800-347-4404 Mon-Fri 6AM-5PM, except Thur 6AM to 3PM, Pacific time.
- Precor Customer Support Team
Feb 28, 2012 | Precor C966i Treadmill C 966i
Der Sir;
The power switch is failure , you must Change the switch. You must be shure the some wires is Not loose, otherwise the wires will be touching the carcase causing the spark inside. Retight the wires or solder .You must inspect the main motor board and all the element around . If someone is burned or other wires is touching the carcasing producing the spaprk.
sincerely. God bless you.
ernesto cuadramanagua, nicaragua c.a.
Feb 28, 2012 | Precor Exercise & Fitness
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
Jan 30, 2012 | Gateway 300 X PC Desktop
NewAir AC 1400E. No green light on plug. Pushing reset button does nothing. Has been running OK. Outlet is live. Does not need draining. Any ideas?
If the reset button is not doing what it should. Try these solutions listed below::
Remove and replace the water collection bucket. Making sure the float valve (if your has one) inside the top of bucket is not stuck in the UP position. Also, be sure that the bucket fits squarely into the holder from top to bottom. If it doesn't, it won't trigger the buck removal safety switch.
If that didn't work do the following:
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
Wait 15 minutes, plug the unit in and turn the Master ON/OFF Switch to ON.
Generally, doing the above, allows the unit to reset and revert back to the original factory settings and you can proceed from there. If it still does not work, there may be a problem with the cord & reset switch. The best way to find out is test the continuity of the cord, with a multimeter.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 15, 2011 | NewAir AC-1400E Portable Air Conditioner
One year old Danby dac8075ee, HAS NO POWER, what could be wrong ? please help
your air conditioner has no 'power' on it's own. It must get the power from an electrical outlet.
It is possible that the outlet you are plugged into is 'dead,' i.e. not working. One simple way to test this is to plug in another electrical appliance, hair dryer for example to test it and see if it's working.
If you do this and the other electrical device works then you know your AC is getting the 'power' it needs to operate - in which case you have a problem with your AC, and will probably need to call a Service Tech.
If, however, you plug in another device and it - too - does not work then you know the problem is within the outlet, probably a 'breaker' that is off or has tripped off. So, you need to locate the breaker - box.
This "breaker - box" (in most houses) will be located in the garage, utility room, or behind a door somewhere in the house, i.e. kitchen or bedroom.
If your outlet is not working - just go to the breaker box and open the door and look for a breaker (looks like a light switch) that is in the off position or perhaps half way off and half way on. Once you find this breaker - be sure your AC is plugged in and - just flip it (breaker switch) back in the "on" position.
Note: if the breaker switch trips right back off - then you know you have a direct short in your AC and probably will need the help of a Service Tech.
If this is the problem and the breaker stays in the on position and the AC runs and cools - you are probably ok, unless the breaker trips again in a short time span.
If that happens you most likely have a problem in the unit although it's possible the breaker is bad - in any event you are probably in the need of a Service Tech.
good luck!
May 05, 2010 | Danby DAC8003D Air Conditioner
Workcentre M15i won't turn on after poss outlet short
turn it off
unplug it
wait a few minutes
plug back in
turn on
Feb 17, 2009 | Xerox WorkCentre M15i Laser Printer
Precor 9.21 Treadmill Logo
1,465 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
