Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
I simply disconnected my ltv 32w6 and now I have no volume. can you assist me ?
  • 11,361 Answers
Do you mean no sound or no volume bar on the screen when you push the volume at the remote or at the TV?
If it has no sound, then:
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 21, 2010
Why doesn't it stay on channel?
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
Mar 12, 2016 | Westinghouse LTV32W6HD 32 in. LCD...
Westinghouse ltv 32w6
check your antenna you should still get the programed channels
Oct 08, 2013 | Televison & Video
My Westinghouse LTV-32w6 HD has sound but no picture
You may have problem with the T-C0N board, worst case will be the main logic board, try cooling the T-CON board with electronics freeze spray to see if the problem will go away, you can get it from Radio Shack.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 30, 2010 | Televison & Video
After about 2 or 3 hrs my Westinghouse 32'' LTV-32w6 screen starts to turn into line like the picture is all grainy how do i fix this problem?
Does it look like this? http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You may have LCD controller board overheating problem (the pictures show the board with shield removed)
Try cooling it with small fan blowing at the vents.
Mar 28, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound cuts out in Westinghouse LTV-32w6 HD TV
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
Jan 06, 2018 | Westinghouse Televison & Video
LTV-27w2 power
This sounds like a bad flyback unit om the main circut board....part cost is around 70.00
Dec 11, 2008 | Televison & Video
LTV-32w6 won't turn on
were on the power supply is the fuse located
Nov 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
Jul 06, 2008 | Westinghouse Televison & Video
Phillips universal 4n1
what are the codes for the DVD player named cyberhome?
all codes please...thankyou
Jan 13, 2008 | Philips Magnavox Learning Universal Remote
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
117 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
