Question about Freezers
The little round door that lets out the ice from the ice maker in my refrigerator is broken. The hinge is broken on one sides of the round door. How do I replace this? The model number is MZD2766GE it is a Maytag refrigerator.
  • 4,070 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
This diagram shows your dispenser parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47964&diagram_id=674334#d674334
Posted on Aug 21, 2010
Why does my ice maker not get cold enough to produce ice? I have a Samsung RFG297HDRS French Door refrigerator. Everything is functioning except for the ice maker. Water is getting into the ice maker
Ok Randy, Lets fix it.
My name is Peter. I am a retired refrigeration field service technician.
You are not getting cooling air to your ice maker freezer compartment. Once again Samsung - bad design - put a ice maker in the fresh food section.
So, you have a ice maker enclosed next to the fresh food section where the recommended temperature setting is 35-40 degrees F.
Where as your recommended freezer temperature is +2/-2 degrees F.
There is a air damper/vent from the bottom freezer in the back of your ice maker housing. Lets remove the ice maker to check for ice build up. On the left hand side of the housing on the wall there is a long narrow cover plate. This is where you connector harness is located. There are 2 screws holding the front end in and a tong and groove tab in the back. Remove the cover plate.
Now, pull the harness out.
Lets remove the ice maker assembly. There are two screws in the front end securing the ice maker to the top of the casing. These screws are recessed. They are either Philips heads or hex heads (1/4"). If they are hex head, he recessed hole diameter is small. Some hex head hand tools will not fit. A screw gun will work or a small outside out side diameter hex head hand tool.
Remove these screws. In the back in each corner is a tong & groove. Pull forward to release the ice maker. Using a small flat head screw driver wedge the wire harness to release. Set the ice maker aside.
Inspect the air vent/damper for ice build up. Use a hair dryer to defrost.
I do not believe you have a automatic damper controlled by a thermistor (temperature sensor). If you do, Remove the damper assembly. Get your multi-meter. Set your meter to the lowest Ohm reading (Omega on your meter) Touch the two probes on your meter together, you meter should read 1.0. Disconnect the 2 motor contacts. On the motor place one probe on one contact and one probe on the other contact. If the meter still reads 1.0 the motor is bad. If the meter reads 0-50 Ohms the motor is good.
If there is no ice buildup & the damper motor checks out, replace the temperature sensor.
You will find getting the wiring back into the side panel will be a little difficult. As usual, Samsung is not service friendly.
Oct 22, 2014 | Samsung RFG297HDRS 29.0 CuFt French Door...
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Jun 27, 2014 | Samsung RS267TDRS - 26 cu. ft. Side by...
Jrsde229....why won't my ice maker door will not open fully
On the left side there is a small hinged cover used by the IR ice level sensor you need to push in on that door and then you can open the ice maker cover flap
May 24, 2014 | Freezers
Where is the ice maker reset button on a Samsung RS265TDRS?
This ice maker is on the door, so
remove ice bucket
move your fingers up under the ice maker tray guard on the left side until you find a button
you may have to press this several times, perhaps hold down firmly until you see some action
then quickly replace bucket & close door
Sep 06, 2013 | Samsung RS265TDRS 25.5CuFt Side-by-Side...
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
Apr 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Freezers Logo
64 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
