Question about Mitsubishi Heating & Cooling
I have the Mitsubishi G inverter. When it is on heating it is blowing tepid air. Can this be fixed.?
  • Mitsubishi Master
  • 43,501 Answers
I'm sure that the problem can be fixed...
here is a tip about Mitsubishi units and how to aaccess all of the manuals for them...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 21, 2010
Mitsubishi heat pump blows cool air when set on 70 in heat setting. It will be 3 years old in January.msz-fe18na
Cooler than normal discharge air temperatures are kind of nature of the beast for an inverter compressor system. An inverter compressor has essentially an infinitely variable output due the varying speed of the compressor. When is is running slower the transfer of heat is less than when it is running full bore. At least on a mild day. On a cold day, even running at full speed, the leaving air temperature can feel a bit cooler due to the lack or heat available in the outside air to transfer in to the indoor coil. The Mitsubishi's are capable of running down to 5 degrees above zero without the addition of a low ambient control kit and the nearer it is to that temperature, the lower the leaving air temp will be.
There's only about three more 300 page VOLUMNs of information available to describe the function of these little guys, but maybe just a taste of the info will satisfy your concern. Of course what's written above is a very Cliff Notes version with a lot of holes in the description.....but you get the drift.
Dec 18, 2014 | Mitsubishi Heating & Cooling
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
1993bonneville3.8litrenoheat
I bet you didn't remove your heater hoses where they connect to the engine to check to see if they are clogged with corrosion. This corrosion can also clog up your heater core.
Dec 08, 2013 | 1993 Pontiac Bonneville
New water pump, thermostat. Heater blowing tepid to cool air since replaced.
sounds to be a faulty thermostat did your car over heat my vehicle does the same thing its the thermostat when its cold out your vehicle loses all its engine temperature and blows cold air make sure you use 50/50 antifreeze
Nov 29, 2010 | 1996 Chevrolet Camaro
Freon is full but a/c blowing hot air
Do you know if your compressor is engaging, if its not there are a number of switches and sensors that could be faulty
Apr 11, 2010 | 2003 Toyota 4Runner
I've noticed blower very weak , air tepid at best.
IF YOU HAVE A CABIN FILTER IT MIGHT BE CLOGED.
Feb 02, 2010 | 1999 Saturn SC
The heat is not getting hot and keeps turning off
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
heatman101
Jan 31, 2010 | Mitsubishi MSZ-A15NA Split System Air...
2001 Mitsubishi Montero Limited. 122k miles.
2003 Mitsubishi Montero Limited. 97k miles. Temp gauge is erratic when actual temp is normal. How do I fix this?
Nov 13, 2009 | 2001 Mitsubishi Montero
2.2crd blowing tepid air on internal heating while running at normal temp
this is common, as you can not shut off the heat on these cars, my suggestion, set your heat control to medium, between hot and cold, to a comfortable temp. This is one of the things that stops alot of people from buying chryslers.
Nov 25, 2008 | Chrysler PT Cruiser Cars & Trucks
Open Questions:
Heating & Cooling Logo
2,454 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
