Question about Proform iLog 750 Treadmill
How do you get the running deck down? - Proform iLog 750 Treadmill
    Problem Solver:
  • 13 Answers
If you are saying that the deck is in the folded position and will not fold down then pull the pin on the left side of the deck. If the pin is stuck then try and plug in the treadmill insert the safety key and push the down incline button on the console. This should make it so that the pin will un-jam.
Posted on Aug 21, 2010
Treadmills are shutting down after persons are running on machine. The power is tripping, shutting down. After break or machine is turn on it works again
Chances are the treadmill started by shutting off in the middle of a workout and has gradually gotten to the point that it will not run long, or turn on at all, in some cases. This is most likely caused from a worn deck and belt. If the belt and deck is not routinely waxed, it wears down and causes friction. This friction builds up heat which can fry your electronics. The machines circuit breaker shuts the machine down to protect the major electronic components. This protective measure, built in by the manufacturer, will only help for so long. After a few times of shutting down due to the heat, it actually does damage to the electronics. The result and correction usually ends up being a new deck, a new running belt, and in most cases that have gone on too long, the motor control board. I am attaching a link for the service manual for further information. Parts for Matrix T3 Treadmills T3x T3xi Belts Rollers Decks SPORTSMITH...
Aug 27, 2013 | Matrix T3x Treadmill Deck Treadbed Parts
My Powerfirst T960 stopped twice while running. Display stays on (no error message) but backlight turns off. Also, was speeding up/slowing down while running
1)LUBE THE DECK BELT, this problem is by lack of maintenance schedule, maybe you have deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for protect the electonic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board, for the input voltage motor, if there are NOT the board si faulty.
5) RUN the software calibration for diagnose, troubleshooting and fix it.
see my person TIPS for help.
sincerely. God bless you
Apr 18, 2012 | Exercise & Fitness
I have a MTD lawn mower is believe is 21hp with a 42 inch cutting deck, its been chewing up deck belts, i just recently had it gone thru and had the tech replace the deck brakes one was severely worn and...
sounds like one or more of the pulley bearings is frozen or turning very hard just jack up the mower and check each pulley how easy it turns replace bad one hope this helps
Apr 18, 2017 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
How to remove shaft assembly from mandrel housing of a husqvarna yth2348
It's much easier to do on the tractor.
1. Leave deck installed.
2. Jack tractor up and lower deck.
3. Run a heavy wire through the mandrel pulley's tie down hole.
4. Raise deck and tie wire around the deck.
5. Lower deck and remove top nut.
6. Raise deck and remove shaft.
You can modify this procedure to loose the nut if you don't have a jack and remove it once the deck is off. Retorque nut to 35 ft. lbs during install.
Apr 25, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a craftsman gt 5000 model 917.276220 runs fine but when mowing deck is engaged it wants to die when under a load or cutting tall grass, it will stay running but when i start to cut it bogs down?
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
Mar 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Aug 09, 2010 | Precor 9.31 Treadmill
My Precor 9.21 si Treadmill shuts down upon occassion when running over 8 MPH. It is most likely to occur when changing speeds, especiialy if you hold the up or down arrow for a while to get it to speed up...
Hey Doug,
Just wondering has this unit ever had the running deck flipped over if not this may be sighs of worn deck or belt or both! What is starting to happen is that at the higher speed the unit is starting to draw more current, so the motrol control board will sense this and will shut down so it won't damage either the motor or board. What starts as an occassional shut down will progressively become more frequent. Simple test is put your hand palm down between the belt and deck,if you feel uneven ridges then the deck needs to be flipped over and when you pull out your hand out and their is a black sooty film on the back of it ,then that seals it this means that the composite material is being shaved off. Most likely the belt will have a smooth glazed feeling in the middle part of it. and well also need replacing.
Mar 14, 2010 | Precor 9.21 Treadmill
How to adjust mowing deck
there are threaded anchors that hang down on each side of the deck just uder the foot boards; if u run the nut on them up/down it will raise/lower it. Be sure to do this on a level floor to ensure u dont raise one side higher than the other causing it to cut crooked.
Feb 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
May 23, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Proform iLog 750 Treadmill Logo
239 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
