Question about DeLonghi Pinguino PAC-260 Air Conditioner
Delonghi pac260 ac unit blowing hot air - DeLonghi Pinguino PAC-260 Air Conditioner
  • DeLonghi Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 21, 2010
Repair manual for Delonghi ct90 air conditioner
check that the compressor is working ( feels hot)
call a technician to check gas pressures and start /run capacitor for the compressor motor
Jun 11, 2016 | DeLonghi Heating & Cooling
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
I do not have the exhaust hose for my AC. Should I not run the AC since it is blowing hot air into the room as well as cool?
No you should not because it is counterproductive. You can always purchase a new exhaust hose at your local hardware store!!!
Aug 10, 2011 | DeLonghi Pinguino PAC-210 Air Conditioner
Delonghi Pinguino K900, continued to blow hot air, what should be the solution. I want to enjoy the airconditioner aspect of the unit.
There a several things that can cause the problem you have described.
1. The Dehumidifier Mode is operating at the same time as the AC or is operation on it's on.
In dehumidifier Mode heat is produced.
2. Air filter needs to be removed and cleaned.
3. A blockage or crimp in the exhaust hose.
4. The exhaust has a leak or has come loose from the unit.
5. The unit is sitting in direct sunlight or is adjacent to a heat producing appliance.
6. Compressor needs to be recharged with R134a refrigerant gas.
The 6 things listed above are where you need to start troubleshooting. 5 of which are easy to check and correct.
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Only a third of the vent is blowing air
hello. here is a link to some helpful info. http://www.sylvane.com/delonghi-pac260.html
THis unis is no longer being made so finding a manual will be a challenge. Remove the filter and use it without one for tonight. then get a new filter tomorrow. be cool.
Aug 12, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
AC Wall unit is blowing hot air
Bit difficult? Brand/type of this AC?
Can't see what controls what from here.
Your fan works, but I can't see your compressor working to compress the freon (or what ever is in there).
So give some more details about electrical connection.
2 / 3 phase /grounded?
Suppose the unit is disconnected now and thawed up?
Apr 17, 2009 | Heating & Cooling
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC-260 Air Conditioner Logo
560 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
