PIONEER DCZ-92 WHERE CAN I GET REPLACEMENT TAPE DECK BELTS
  • Scott Frye
    Scott Frye Aug 23, 2010
    Hi....
    Is this an all-in-one system?
    I would try studiosoundelectronics dot com 1st , for the belt
  • 518 Answers
SOURCE: tape deck is broke sounddesign model 5959
If the motor is running but the belts are not, then they are probably shot. You can buy belts by size or buy a belt kit at MCM Electronics.
If the motor is not running it could be 2 things: 1. A bad motor or voltage to the motor.... 2. A bind. I've seen the grease on the capstan bushing get old enough to turn into a very hard tar. So check the motor and capstan for freedom of movement.
Hope that helps you get it working...
Geno
Posted on Mar 26, 2008
  • 104 Answers
SOURCE: belt replacement in a sony tc-wr645s tape deck
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
Posted on May 23, 2009
SOURCE: I need replacement drive belts for an Onkyo
www.vintage-electronics.cc/vbelts.html
Posted on Jul 21, 2009
Grubhead
  • 5390 Answers
SOURCE: replacement drive belts for Sony HTC-H2900 tape deck
CPC, Chas Hyde, Willow Vale, Wizard.
Or you can measure the diameter of the belt and enter it into google. IE 60mm drive belt.
Posted on Jan 05, 2010
  • 108 Answers
SOURCE: The capstan drive roller on my tape deck fell
You need to locate the supplier of pinch rollers that will fit your tape deck. If that fails, you have a useless piece of gear. If the unit is of decent quality, you should be able to locate a supplier. You didn't include the make or model, so good luck.
Posted on Oct 07, 2010
Where can I get replacement belts?
They are hard to find but try the MCM Electronics catalog. You will need to know the dimensions of the belt (i.e. width, length...).
Good Luck !
Apr 25, 2016 | Pioneer CT-W205R Single Dual Cassette Deck
How do i install belts on a pioneer ct-4 tape deck
You take the deck block out of the chassis and then removed thrust plates and other parts to gain access to flywheels and other areas.
It takes time to get into these but it is not impossible.
Aug 21, 2014 | Pioneer Audio Players & Recorders
Pioneer CT-W350R Double Cassette Deck will not playback.
Might need belts and a good cleaning.Rotation sensor not detecting reel table rotation. It is doing what it is suppose to do when at the end of the tape but you tape may not be at the end.
Nov 20, 2012 | Audio Players & Recorders
Pioneer Cassette Deck Repair
Anything that eats tapes means the take-up torque is low of stopping due to bad belts or a bad Idler system or even cracked tires. The transport have to be taken out and those parts replaced and then it will work again.
Feb 05, 2012 | Pioneer Audio Players & Recorders
Trying to locate a pioneer cassette player, tape drive belt, for CT 506 model.
I'm not sure what country you're in but below is a link for a complete set of 5 replacement drive belts for your CT-506.
http://www.vintage-electronics.cc/pioneerkits.html
If you need any further assistance then just ask.
Please leave feedback.
Cheers
Andy
May 09, 2011 | Pioneer Audio Players & Recorders
I need a complet set of belts for my Pioneer CT-W103 Double Cassette Deck.
Just measure the diameter of each belt (in mm) and then search with Google. Belts are generally not maker specfic.
Aug 15, 2010 | Pioneer CT-W103 Single Cassette Deck
Replacement drive belts for Sony HTC-H2900 tape deck
Dec 29, 2009 | Sony Audio Players & Recorders
Casette deck drive belts broken
If they are just worn then you just need to look where they go. Take a photo or draw it! If they are broken and not clear how they attached then it will be hard. You might need the service manual if that is the case.
Jun 06, 2009 | Pioneer Audio Players & Recorders
119 people viewed this question
 Grubhead
Grubhead
