Acer aspire desktop. Screen suddenly dims a fraction then the screen goes black. It a driver problem or a problem with the video card. Could the problem also be a in the monitor itself. The current video card i think is a NVIDIA GeForce 7100.
  • 644 Answers
What you have explained it sounds like the monitor itself is faulty and nothing to do with the computer, it may be worth trying another monitor to see if the same thing happens.
If the screen is fine with another monitor, then your monitors lcd backlight is beginning to fail, these can be changed out but can be fiddly.
Next it could be the graphics card, is it the original, or has it been updated to this one, it could be your power supply is on its way out, and is not pumping out enough watts to power the graphics card properly and therefore you are getting the fade that you speak of. The power supply in these computer are normally no more than 300watts, so upgrading these computers do somtimes involve upgrading the power supply first.
hope this helps and post back what you find.
Posted on Aug 21, 2010
Have video issues on my Acer Z5600 23 inch touch screen. can anyone help? Ever since this thing updated I have not been able to play any games. if it goes to a full screen res then it goes to flashing from...
hi i have an aspire z5600 when trying to play an installed game the game starts then the screen goes black but i can hear the game behind the black screen ! hope you can help thanks .
Stu
Nov 26, 2010 | Acer Aspire Z5600 PC Desktop
Acer Aspire 5610. LCD very dim all of a sudden.
That sounds just like an inverter problems. There is a slim chance the bulb could be a problem, but I would replace the inverter. It is not too hard to do, no soldering involved.
You have to remove the screw covers on the frame of the LCD frame, and then carefully pop off the frame. The inverter should be on the bottom center of the screen.
Be careful, there is a high voltage in that little baby. Just get the full numbers, and do a search on the internet and buy yourself a new inverter to replace the old one.
Apr 08, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 5515 backlight problem
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
My acer 9300 when switched on shows a blank screen (black with some faint white back ground) but the process of starting windows goes normally coz i can view this when connected to a monitor whats a miss ?...
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 25, 2009 | Acer Aspire 9300 Notebook
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5315 Notebook
Acer 22 in monitor
From what you say, I'll assume you see stuff on the monitor like the BIOS info,and the Windows splash screen. Then it goes black.
This happens when Windows loads the video drivers for your video card. Up until that point, you are using generic VGA drivers. I would guess the drivers are corrupt and the video card just stops working when it tries to access them.
You'll need new drivers for your card (you'll need to determine that--you can ask me directly by clicking on my name if you need help there). Then you'll need to start your computer in safe mode and remove the video card from the device manager. Depending on the directions you have for your video card, you may have to tell the computer not to install drivers when you restart your computer, but run the install program first.
Feb 27, 2009 | Acer Computers & Internet
Acer Aspire 5920
Are you using a built-in video card? it's a video card problem. It's either the memory alloted for your video card is too small. Another thing is the driver of your video card needs to be updated.
Please do these steps:
Right-click on the Desktop > Properties > Settings tab > Click Advance button at the bottom > Go to Adapter tab. Tell me everything under the Adapter Information.
Thanks!
Jul 28, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
