Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool super cap plus over flowing water
Water overflows out of the top lid
    Novelist:
  • 161 Answers
The water level switch has a tube attached to the bottom of the outer tub and will not work if there is a hole or break anywhere.
If the tube looks ok then the switch must be replaced.
Posted on Dec 21, 2008
How do u take off top of dryer
The back panel has screws holding it to the top lid.
The top lid just pops up .
Nov 12, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool heavy duty super capacity plus is acting funny. it will run water and then it i will not spin and will not drain water. it will agitate, but when it does it makes a funny noise. what could be...
Could be a few problems. Bad lid switch could be the problem but also could be other things. The agitator noise is something probably you should let a technician hear it could be as bad as a bad transmission. That could also be the cause of the other.
Dec 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Losing water from radiator cap have tried replaceing but problem still there is there diferent caps or is the fault with radiator local garage says no
You should not be losing water from your radiator cap. When the water in your system reaches such a pressure that it needs relief, it will normally flow into the overflow tank (the opposite occurs when the system is cold; water flows from the overflow tank into the radiator).
So, the first thing I would do is to get the proper cap for your radiator.
Second, I would check to make sure my cooling fan was running (I'm assuming that you lose water when the engine is hot).
Third, I would make sure to bleed the system if I had to add a significant amount of water (bleeder should be on top of the fitting that your top hose goes to; loosen and observe until water flows cleanly without bubbles, then close).
I have to think that your cap, new or not, is the problem.
Hope this helps you.
Nov 15, 2009 | 1998 Honda Accord
My Whirlpool electric steam dryer accumulates an unusual amount of water in the exhaust vent (to the degree that it overflows the hose). Suggestions?
That can happen when the vent hose is clogged. Usually a birds nest or just an accumulation of lint out the outlet point.
Aug 25, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Will not drain water after washing
it sounds like your lid switch ic either broken at the lid or it is non functional open the lid to manually see if it is broken you schould be able to see it visably on the lid if it is broke your machine will not go into spin and not drain
Nov 24, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Heavy Duty Super Capacity Plus not spinning
HI thanks for the question . On your model thers is no belt it is a direct drive.IF the washer stoped pumping the water out in pump out then your problem is with the lid switch. The lid switch is located under the top Thanks for your question hope this helps you ,THE appliance doc
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Robert Rankin
