Question about Water Pik Shower Head
How to open shower head ? - Water Pik Shower Head
If the head will not open up your best bet is to submerge the entire head in white vinegar.the vinegar is non-acidic and won't cause any damage to the plastics or metals.
This will rid the shower head of limescale and debris.
Posted on Aug 27, 2010
  • 85 Answers
Just rotate the head in anti clockwise
Posted on Aug 21, 2010
I installed a Moen L2353E tub/shower faucet and water won't come out of shower head
Couple of ideas: If you don't get water at all first check to see if the shut-off valves are open. If so, close them and remove and clean the cartridge. If water comes from the spout and not the shower head, make sure the diverter (the handle on the tub spout) moves up when you pull it. If that works, remove and clean the shower head since there might be debris blocking the water flow. Without
more info this is my best guess.
Apr 07, 2015 | Moen & One Handle Tub & Shower Faucet
How to open a shower head
Get CLR from walmart or target or Canadian tire etc and apply to remove the build up. once the showehead is out, dip it in the CLR and it will be like new! Good luck
Jul 17, 2013 | Home
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
No water from shower
Remove the shower head and try flushing out the pipes by turning faucet wide open on each side, Then chk shoer head for any sign of scale being in the water. If there is, Your water heater needs draining, cleaning, descaling. good luck, Ned
Oct 18, 2009 | Home
For some reason, my rain shower head drips like it is slightly turned on. I have never noticed this problem until I changed the thermostats and elements in my water heater. I believe the shower head is...
Remove the shower head and flush the plumbing by opening both valves fully. When you did the heater work, you dislodged some scale . Now it's in the shut off valve. It's no big deal as long as you hsaven't forced anything to stop it. Good Luck_Ned_
Oct 18, 2009 | Jaclo Wall Mounted Flood Shower Head -...
Water does not come from the shower head
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Jul 24, 2009 | Delta & Single Handle Shower Faucet
Moen shower head leak
Single handle shower controls always have some water trapped inside. It has probably freeze damaged the cartridge
Apr 29, 2009 | Moen & One Handle Tub & Shower Faucet
Tub shower combo... newly installed but leaks from shower head when turned on
Some shower heads require a rubber washer that would fit in the opening in the shower head. That may be all you need and would be the simplest fix. Check that first.
Sounds like you need some teflon tape available at any hardware store. The teflon tape should be wrapped around the pipe threads with 2 or 3 wraps and then screw the shower head on to the pipe. If the leak is in the wall, remove the shower head pipe from the wall pipe elbow and apply 2 or 3 wraps of teflon tape to the shower head pipe threads and reinstall to the elbow in the wall. You may need a pipe wrench if the pipe is real tight. Good Luck
Nov 30, 2008 | Dishwashers
Water Pik Shower Head  Logo
1,392 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
