www.fixya.com > ... > Cars & Trucksfiring order for a 1992 Suzuki Sidekick 4 cylinder 16valve The firing order is 1, 3, 4, 2. ... I have a 2003 Suzuki Aerio and it stopped running. ... firing order diagram 2004Suzuki Forenza firing order diagram which engine?, but all 4 bangers not ... ...firing order for plug wires 2007 suzuki forenza 2.0 engine Look at the engine.
The firing order for a Dodge 318cid/5.2L is 1-8-4-3-6-5-7-2 clockwise rotation.
Cylinders are numbered like this.
Pass side 2-4-6-8 front to rear.
Driver side 1-3-5-7 front to rear.
The firing order is probably forged into the intake manifold. Number one tower on the distributor cap is the one facing the number one plug or the driver-side headlight.
Distributor rotor at Number 1 plug terminal points to front intake bolt on left side of engine.
The firing order is 1-4-3-2. The cylinders are numbered from the front of the car with 1 & 2 being on the passenger side and 3 & 4 on the driver's side, so #1 and #3 are closest to the rear seat. The distributor turns clockwise and there is a scribed notch on it to mark the #1 position. Hope this helps.
Here is a firing order diagram for your "Jetfire Rocket" engine, and you will not find this diagram out there because I just made it to help assist you using the Windows "Paint" program and a firing order diagram from an ancient 1964-1971 Chilton Manual.
Here is the firing order for that vehicle and engine, that is if it does have a Buick engine with the distributor mounted on the front of the engine, but if the distributor is mounted on the back of the engine then it is an Oldsmobile engine and I have that firing order diagram also if you require it.
For the 1994 VW Golf: I do not know if you have the 1.8L SOHC In-Line 4-Cylinder or the 2.0L SOHC In-Line 4-Cylinder; however I have included both below:
For the 1.8L SOHC In-Line 4-Cylinder Firing Order: 1-3-4-2 Cylinders: ..........(back)......... |...1....2....3....4...|
..........(front) Distributor:
...(back)
(+)....1
...2.........3
........4...(+)-screw
For the 2.0L SOHC In-Line 4-Cylinder: Firing Order: 1-3-4-2 Cylinders: ..........(back).......... |...1....2....3....4...|
......(back)
.....2.......1
(+)............(+)-screws
.....4.......3
......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
The firing order is 1-4-3-2. From looking at the motor, cylinder 1 is right rear, cylinder 2 is right front, cylinder 3 is left rear, and cylinder 4 is left front.
