Question about HP PSC 950 All-In-One InkJet Printer
Copy problems Whenever I use the hp 950 to copy I wind up with a 4 inch black line on the left side of the paper. Any ideas how to fix it?
  • Georgia B
    Georgia B May 11, 2010
    Are you closing the cover when you scan?
    Guru:
  • 1,342 Answers
Assumed solved. No reply to clarification request.
Posted on Jul 26, 2008
The "CIS" scanning device on the scanner is broken. Replace the entire printer because fixing it is more expensive than a new printer.
Posted on May 04, 2008
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
I have a HP OfficeJet 6210 all-in-one printer...whenever I make a copy by inserting sheet into feeder a long black line appears on the page. It is as if there were a long black line on the original. This...
I have the same printer and have the same problem. I found out though that sometimes this works: when you make a copy, select the best quality option. Again this only works sometimes.
Dec 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
Back line on paper
Hello sir; You may try to make a copy direct from glass plateform see there have black line or not, if not ,then you have to clean the piece strip glass on the left hand side of the plateform. that will take care the problem. good luck.
Dec 09, 2008 | HP 5510 4-in-one Printer
Black lines on every copy
Good morning Jean,
A mark that is three inches apart can either be the drum, which is part of your toner cartridge, or the fixing assembly, which heats the toner and makes it stick to the paper. With both problems you are describing it could be either of these. The easiest way to figure out which it could be would be to replace your toner and see if the problem persists or if the machine is fixed. If you rub you finger on the left side of the page where the problem is does the toner rub off? If this happens then the fixing assy needs to be replaced. It could also be a combination of both problems. If you replace the toner it could fix part of the problem or vice versa.
Hope this helps
Dec 01, 2008 | HP LaserJet 3200m All-In-One Printer
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP PSC 950 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
