Question about Pride New Mobility Victory XL 4 Wheel Scooter
I bought new batteries this year and it seems to have lost its power the batteries I bought were larger than the last ones so they would handle the load. it slows down and speeds up and stops and trips the overload switch
  • 692 Answers
You have a speed control and/or throttle pot problem. This can also cause a cb trip
Posted on Aug 21, 2010
When I turn key on I have head light but no instrument lights and it won't turnover
I would suggest you check the wiring loom around the headstock as you were able to cause symptoms when moving the handlebars. You may have a broken wire inside the loom so you will have to open it to inspect it.
Apr 09, 2015 | Power Motorcycles
Continous whine sound on APC Surge Protector 600
Hello Glen,
Yes, The batteries in UPS systems have a 2.5 to 3 year life span so your unit does need new batteries. The whine is usually caused by the charge circuit trying to push the charge to the damaged cells in the battery. You should be able to get replacement batteries from your local battery dealer, no need to order "special" UPS batteries. Open your UPS cover and remove the old battery and bring it to the dealer and they will match it to their stock.
Jul 19, 2012 | Computers & Internet
Have a pair of mt800, use them with headset for bikers, tangent on sterinhandle and so on. Bought them last year and were wery happy with how they worked. This spring when we took out our bikes and of...
While not familiar with that model in the US, I think it is a battery issue. It is common for Lithium batteries not to last for a year on the less expensive brands. There are many qualities of batteries, buy at least one to try, or a pair. It never hurts to have a spare. Radios (or phones) on transmit require a lot of power compared to standby.
Jun 02, 2017 | Cobra Radio Communications
How many years does the batteries usually last? I bought an used quad power wheel. I charged the battery for about 6 hours and it doesn't seem to have any juice. Before I buy a new battery is there any...
if you happen to have a power supply with the same voltage you can hook up that to the toy and see if it even runs before spending money on the battery, the batteries last according to the amount of use and how many times they have been charged
May 22, 2011 | Fisher Price Power Wheels Kawasaki KFX...
Battery seems to be charged, it will crank 90% of the time but once in a while i have to jump it off. this started when i left the dome light and rear inside light on all night and the battery lost charge.
Maintenance-free batteries really don't tolerate complete discharge very well. If the battery was already several years old, letting it go dead probably was the last straw, so now it may not hold a charge more than a day or two, or it may have so little capacity that if you start the car a couple of times without a long (20 min+) drive between starts to recharge the battery, it won't be able to start the car the next time without a jump. Probably time to go battery shopping.
You didn't mention your model, but many BMWs use unusual battery sizes (group #s). Most of us use a smaller, common size battery, or a larger (longer) battery because original sized batteries are hard to find at the retailers, and when you find one, it may not be very fresh. If your battery will only last six or seven years at best, you don't want to buy one that is already a year old, and has been sitting on the shelf partially charged for that year.
Mar 05, 2011 | BMW 325 Cars & Trucks
I bought an xps 210 2 years ago. The power supply is dead
It is possible that you picked up a faulty power supply, slim, but possible. Chances are pretty good that you have one of your components drawing too much current on your power supply. The largest power drain comes from your processor and the graphics accelerator cards, however it could be a faulted motherboard or hard drive. You can replace your power supply with a larger capacity unit from a known good manufacturer. If you increase the wattage capability and look with the side off to see if any component is generating a lot more heat than usual. A larger capacity power supply should be able to handle the unusual current draw.
Apr 18, 2010 | Dell XPS 210 PC Desktop
Power
The battery seems to be bad. I get my Peg Perego Batteries at http://www.shopjandl.com/
My batteries last about 3 to 5 years, as long as my kids are charging them up each time they go down.
Hope this helps
Jul 10, 2009 | Peg Perego John Deere Gator HPX Ride on...
WHEN I HIT THE TALK BUTTON, IT BEGINS WITH A SCRATCHY NOISE AND SOMETMES IT SQUEELS. I HAVE UNPLUGGED EVERYTHING FOR AN HOUR OR SO AND PLUGGED EVERYTHING BACK IN. THAN AS TOLD, I TRIED TO 'REREGISTER' BOTH...
I WAS TOLD THE PROBLEM WAS PROBABLY THE BATTERY. AS THE BATTERIES ARE THREE YEARS OLD AND CONTINUE TO POWER THE UNIT I CAN'T BELIEVE IT'S THAT. IT STATES THAT THE BATTERY SHOULD LAST ONE YEAR AND WOULD INDICATE "LOW BATTERY". THE PHONES ARE ALWAYS IN THE CRADLES AND POWERED UP. I TESTED THE OUTSIDE LINE AND FOUND NO NOISE. AS THE BATTERIES ARE $20 EACH, I BOUGHT A NEW PHONE FOR $10. SINCE THEN, I HAVE RE-CONNECTED THE OLD UNIDEN PHONES, BOTH IN MY HOME OFFICE AND IN MY BEDROOM AND THEY SEEM TO WORK JUST FINE WITH A MINIMUM OF NOISE. THIS ALL OCURRED AFTER SEVERE SNOW, WIND AND RAIN STORMS.
THANKS FOR YOUR RESPONSE.
TERRY ANDERSON
Jan 16, 2009 | Uniden DECT 6.0 Cordless Telephone...
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Lost Power Cord cant find a new one
I lost my power cord for my Electric skillet and called Wal-Mart number on the back of the skillet and they said it would be able to be exchanged for a new skillet with a cord if purchased within 2 years even without a receipt or a box :-)
Aug 05, 2007 | Rival S16 Electric Skillet
Pride New Mobility Victory XL 4 Wheel Scooter Logo
190 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
