Question about Arris SURFboard® SB5101 Cable Modem
How do i fix it if the online light is blinking
    Novelist:
  • 142 Answers
This light pattern indicates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. This process is known as bypassing the splitters. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If bypassing your splitters resolved the issue than you will need to replace the malfunctioning splitter. Typically splitter only cost a few bucks and can be purchased from any electronic store. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
I hope that information above has helped is some way.
If possible please rate this solution.
Posted on Sep 01, 2010
Blinking red light on my dell laptop
Is it on when you are plugged into an outlet? Check you machines online manual to see what the red light is for.
Aug 30, 2014 | Dell Computers & Internet
Lamp light is blinking as well as the red standby temperature code, tried replacing bulb, still getting lamp blinking light
If the bulb did not fix it then it is probably the ballast that has gone out or the power supply board has failed. I usually replaced the ballast and power supply together. You can call 1-800-samsung or search online for the parts.
Jul 13, 2011 | Samsung Televison & Video
Linny4242@aol.com My problem: I have a GE Quietpower2 dishwasher. The normal wash and heated dry lights continiously blinks, the pump seems to be operating with no water present. I've tried turning the...
It sounds like the main control board has gone wacky....
replace the control board
. That is not that hard to fix and you can easily buy the partsyourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 20, 2010 | GE Dishwashers
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
JVC HD52G887 52 in. HDTV Television lamp light and power light blink alternatel. the lamp comes on and then goes out before the screen is visible and then the lights blink
you lamp may be cracked and need to be replaced or for some reason you may be having a surge, but my money is on the lamp. open it up and inspect the lamp for discoloration or cracks and buy a new one online and replace. This is really a cheap and easy fix
Dec 14, 2009 | JVC HD52G887 52" Television
Online light blinking
change the last four digits on the mac 192.168.100.1
Jul 28, 2009 | Arris SURFboard SB4200 Modem
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Green blinking light
If you don't have the manual for your dishwasher to find out why the green light blinks, try to get the model number off your dishwasher from the inside edge and go online to find a website that provides online manuals.
Feb 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Im having problems getting my modem to get online. The light wont come on. All but the online light come on. The online light blinks then all the lights go off except the power light, and the receive...
Your modem is not synching. It could be a number of possibilities, and you're going to have to do some troubleshooting to narrow it down.
  • Verify that your AC, Cat 5, & ethernet cables are connected securly
  • Verify that your modem is not in "standby" mode
  • Power cycle your modem
  • Try a different cable outlet
  • Call your ISP to make sure your modem is provisioned and your service is set up for cable internet.
Nov 06, 2007 | Arris SURFboard SB5120 Modem
Arris SURFboard® SB5101 Cable Modem Logo
869 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
