Question about HP DeskJet 920c InkJet Printer
Color ink I know it says I cannot use it without the color, but is there anyway I can bypass this? I am very sick and have no way to get out and get the color ink and need to print some black and white documents. If not I understand, but it drives me crazy knowing it does not have this feature (to use with black ink only) Thank you, Sick @ Home :)
  • speedyg May 19, 2008
    The best solution does not work.
  • 26 Answers
Try turning off bi-directional support in your printer preferences
Start->Control Panel-> Pritners -> (Right click printer)->Preferences-> Ports
uncheck "Enable bi-directional support"
Posted on May 07, 2008
Even when all properties are set to 'black & white' our Phaser 8550 won't print without all ink colours LOADED. How do I bypass this need so we only need/use black ink?
Only loading black ink and printing monochrome only is not an option on this machine. It must have color cubes installed to keep printhead purged and operating normally.
Sep 03, 2013 | Xerox Phaser 8560DN Laser Printer
Trying to remove color cartidge error if not using color bliinking orange light
Unfortunately no, Printers require both cartridges to be installed and operational to enable the printer even if you are only printing black text. No way to bypass this "feature".
Feb 15, 2013 | HP DeskJet 950c InkJet Printer
My printer says i am out of ink (colored) is there anyway to overide this as i only need black ink
No, sorry but I am not aware of any such bypass solution.
What you can do is get the ink cartridge refilled by a local vendor, that will cost you less and as you said that you will be using mostly the black so quality does not matter in that case.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Nov 22, 2011 | HP Office Equipment & Supplies
My Canon Image Prograf iPF700 keeps running out of color ink even through all setings are on Black and White (Monochrome). Any suggestions, getting sick of paying for ink im not using.
I you see in the preferences of the printer you have 2 kinds of monocrome( check de advanced option) one uses the all the colors to print in black if you use the second monocrome when you print its not black its more like brown. but this way you dont use de colors inks
Apr 19, 2010 | Canon iPF700 InkJet Printer
I have the Brother MFC440cn printer. Whenever one or two of the color ink cartridges are out, it won't let me print in black ink. Is there a way to bypass this problem without having to buy color ink if I...
Sorry, but no. The machine needs to have fluid in the printhead and ink tubes to keep them from drying out and clogging. And even if you never printed a color page, the machine would use colored ink in its automatic cleaning cycles, shooting it through the print nozzles to blast them clear.
Apr 03, 2010 | Brother MultiFunction Center MFC-440CN...
Empty yellow cartridge, but cannot print in black?
Most printers use a little of all inks in their functioning, just to keep all the inks flowing, so while it is not printing yellow, it uses it in the startup mode to verify function and cleaning mode to clean the nozzles. Manufacturers usually do not put in a bypass for this, because they make money mostly on selling you ink cartridges.
Jan 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Color cartridge plastic catch broke off
reinstall the software and select no colour catage instaled
Jun 21, 2009 | Lexmark Z600 InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Printing without color
Each cartridge must have a certain amount of ink for the machine to run, even though you only want to print in black and white. Hope this helps.
Nov 13, 2007 | HP PSC 750 All-In-One InkJet Printer
HP DeskJet 920c InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
